Building stroker with a 5sfe crank
Postby dlux4life » Mon Sep 27, 2004 12:37 am
Hey guys, i made a post on celica.net asking some questions about the jun 2.2l stroker kit. I was told that it is much mroe cot effective to build one with a 5s crank and 3s forged pistons. I was told that there were some people here on the board that have done this using the 5s crank. Just wondering if i could get anymore input here...here is my post on celi.net
http://celica.net/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=37;t=002765
dlux4life
Postby RedCelicaTRD » Mon Sep 27, 2004 1:56 am
Go to cj-motorsports.com. They have a nice stroker kit that has a fairly low compression ratio. It also comes with everything you would need and alot of the parts are custom from various companies. The pice is a lil high at $2,500 but I like it.
Postby CMS-GT4 » Mon Sep 27, 2004 2:34 am
Thats not a bad price for everything. Should look into how much all that would cost sourcing seperatly.
I think I am going stroker on the 3sgte rebuild.
Postby RedCelicaTRD » Mon Sep 27, 2004 3:05 am
Talk to them about sponsorship.....
Postby maroon_185 » Mon Sep 27, 2004 3:28 am
After going to that site I think I might go stroker on my rebuild also
Chris Fowler
1990 maroon 185 (rc swapped)
1991 red mr2 (3s swap coming soon) Dads
maroon_185
Postby furious82 » Tue Sep 28, 2004 2:18 am
Cost efficient the 5s crank with aftermarket rods and pistons is better, in my own opinion. Pauter makes a great set of X-beam rods for the 5s that are pretty beefy. If you want to use the 3s rods the 5s crank will need to be turned to make the rod journals smaller so the 3s rods will fit. If you do custom pistons and aftermarket rods you may want to look into rod/stroke ratio, but that all depends on what HP level your looking at. Unless its in upwards of 5-600 i would even worry about rod stroke ratio on a 5s crank and rods (aftermarket). That last comment is a wild guess just to let you know. You have a fwd right? Why not just use the 5s block?
Life sucks when you got to much crap to deal with
furious82
Postby RedCelicaTRD » Tue Sep 28, 2004 4:40 am
Ya, if you use a 5s crank and 5s rods you will need to get custom pistons that raise the wrist pin height or the piston will pop out of the block a lil.
Postby dlux4life » Tue Sep 28, 2004 1:42 pm
Ok, so i am pretty sure that I am going to go with the 5s crank and get some really beefy 5s rods. Should i also get 5s pistons too?...becuse 3s pistons wouldnt mate with 5s rods right?...also what would you suggest for a compression ratio?
dlux4life
Postby allblackalltrac » Tue Sep 28, 2004 3:45 pm
The 2.117 stroker is a 5S block, 5S crank de-stroked to 88 mm, custom rods and a set of 87.5 mm custom pistons with a Compression Height of 1.20”. Engine stays none interference.
The 2.069 is a 5S block, 3S-GTE crank, stock or eagle or Pauter rods and a set of custom pistons that has the same compression height than that of the 3S-GTE piston but with an 87.5 mm bore and the valve pockets placed so that the engine stay non interference.
There are a few 2.1L configurations.. use the 3SGTE head
oversquare- 5S block, 3S crank/rods, custom pistons
undersquare- 3S block, 5S crank/rods, custom pistons
square-5S block, 5S crank destroked (offset ground), 3S rods, custom pistons
Of course you can get custom rod/piston combos for a desired rod ratio.
EDIT: forgot to add...and compression ratio...at the end of that last sentence.
SupraCelifragilisticexpialidocious
super- "above," cali- "beauty," fragilistic- "delicate," expiali- "to atone," and docious- "educable," the sum meaning roughly "Atoning for extreme and delicate beauty while still being highly educable."
allblackalltrac
