Turbo Oil Feed/ Retun Lines CUSTOM SS KIT
Postby allblackalltrac » Thu Aug 24, 2006 5:03 pm
88st165
I was wondering if you could shed some more light on the fittings for us.
What sizes are the fittings, part numbers if you have them?
Also I went to KO's website but dont see the one for the 165 oil feed fitting, did you have to send in your old fitting and have them modify it?
Anyone know where I can find the oil feed/return flange on the turbo (ct26)?
SupraCelifragilisticexpialidocious
super- "above," cali- "beauty," fragilistic- "delicate," expiali- "to atone," and docious- "educable," the sum meaning roughly "Atoning for extreme and delicate beauty while still being highly educable."
allblackalltrac
Postby allblackalltrac » Thu Aug 24, 2006 6:45 pm
I just did some measuring and here is what I found regarding the thread and pitch of the banjo bolts and bung fittings:
Gen 3 3SGTE oil banjo bolt thread uses an M12 x 1.25 metric pitch to -3 AN male-to-male adapter
Gen 2 3SGTE oil banjo bolt thread uses an M18 x 1.50 metric pitch to -3 AN male-to-male adapter
Gen 1/2 3SGTE oil pan oil return bung thread uses an M28 x 1.5 metric pitch to -12 AN male-to-male adapter
allblackalltrac
Postby klue » Thu Aug 24, 2006 11:22 pm
i got some lines made by a company that makes aircraft parts. they are pretty nice. i couldnt wait for ko anymore :P
ill get pics soon
Postby Rick89GTS » Fri Aug 25, 2006 4:21 am
klue wrote:i got some lines made by a company that makes aircraft parts. they are pretty nice. i couldnt wait for ko anymore :P
ill get pics soon
I'd definitely like to see those pics. Don't forget! :D
Rick89GTS
Postby 88st165 » Fri Aug 25, 2006 2:26 pm
well i believe that i have the only fitting made for the st165 or atleast i was the only one as of 5 months ago. KOracing said that they were only going to offer it in the SB kit for the 1st gen so i dont know. maybe if you email them you can work something out. as far as the lines themselves i got mine made from aaron at rabidchimp.com and they came WITH the flange for the ct26 which was machined and tapped already for like around $65 if i remember correctly, maybe even cheaper. unforunatly he only makes the return line in -10an so thats why i had to convert it to -12an b/c i used the KOracing oil pan adapter.
-if i were to do it again now i would go back to rabidchimp.com and ask him to make the feed line 5.5" (total length) and leave the side that goes to the block without an end so i can use that -3an 90 degree elbow without having to cut an existing end off b/c if you have ever messed with cutting these type of lines you know it can sometimes be a pain in the ass. *now remember i am not trying to promote rabidchimp.com in any way, im just trying to explain where i got my lines and where i would go get my lines if i were to do it again. i tried pricing all the fitting and lines separatly on summit racing and it was over $170 and those were just for the materials.
-as far as the return line goes i would prob have to do it the same way i did already not unless someone makes a oil pan return fitting in a -10an size, that way you dont have to buy the extra fitting to convert it to -12an. i could go get the measurement up to the fitting so if people wanted to go about doing it that way they can.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby allblackalltrac » Fri Aug 25, 2006 7:57 pm
Kool thanks for the info.
I checked out rabidchimp's website and they offer the lines for $130. Like you, I also tried to duplicate the lines on Summit and came with the same price that rabidchimp sells their kit for - but I am still missing the oil flange and I have to put it together myself, so their price is very competitive.
You mentioned it comes with -10 AN line instead of the -12 AN fitting the KO adapter comes with. Thats no big deal Russel, Earls, Summit and Aeroquip offers female -12 AN to male -10 AN reducer's to make it work. Cheaper than buying the -12 AN 90* elbow and having to cut the line.
They are an inexpensive kit, along with the reducer fitting, a weld on male -3 AN fitting (for the ST165 banjo bolt) and the KO oil pan adapter a complete kit should cost under $200.
I have found all the fittings and adapters to make my own kit with the exception of the oil return adapter - that I will have to get from KO, but I am working on finding another source. Ironically when I was measuring and sourcing the fittings and adapters I would need, it dawn'd on me that the oil feed and oil return are completely different on the GEN3 - I wonder how KO solved this problem seeing how their SB kits for the GEN3 supposedly comes with the KO adapters, hmmmm.
At any rate my kits are almost complete.
I am getting custom turbo oil flanges made up for the CT2x as well as return flanges for the GEN3 3SGTE oil pan. I've looked everywhere and no-one sells them seperately - like its some proprietary part or something, and only offer it as part of their own "kit" - that really pisses me off.
Dont worry I will sell them seperatly for those of you who wish to make your own lines.
I'll have kits for GEN1, 2 and 3 3SGTE's in any block/head/turbo configuration. Just specify what configuration you have and I'll make the kit accordingly. They will be expensive however - about $100 more than the rabidchimp kit with adapters. I use only the best materials - all kits are going to use high quality Earl fittings and hoses.
The first one Im going to make will be for my own car, this will allow me to test and research the final product before offering it others. It will be for a GEN2 3SGTE block with a GEN3 3SGTE head and a CT20B. I'll get pics up as soon as I finsh peicing it together.
allblackalltrac
Postby allblackalltrac » Sat Aug 26, 2006 3:55 am
Thought I'd share the specs of what parts I'll be using in my kit. This application is for the Gen 2 3SGTE block.
-4 AN Turbo Oil Feed Line:
-EAR-320104ERL Fitting, Hose End, Straight, -4 AN, 1/8 NPT, Aluminum, Red/Blue Anodized
-EAR-309104ERL Fitting, Hose End, Auto-Fit, 90 Degree, -4 AN Hose to Female -4 AN, Aluminum, Red/Blue Anodized
-EAR-350304ERL Hose, Pro-Lite 350, Braided Nylon, -4 AN, 3 ft. Length
I chose NOT to go with KO's oil feed adapter, instead I am using JP Autoworks oil feed adapter. It comes in a -4 AN fitting unlike the KO -3 AN fitting. I also chose to go with -4 AN line instead of the -3 AN line because the Pro-Lite 350 hoses only go as small as -4 AN - among other reasons...
-12 AN Turbo Oil Return Line:
-EAR-809112ERL Fitting, Hose End, Swivel Seal, 90 Degree, -12 AN Hose to Female -12 AN, Aluminum, Red/Blue anodized
-EAR-820112ERL Fitting, Hose End, Swivel Seal, Straight, -12 AN Hose to Male 3/4 in. NPT, Aluminum, Red/Blue anodized
-EAR-350312ERL Hose, Pro-Lite 350, Braided Nylon, -12 AN, 3 ft. Length
I WILL still have to use KO's oil return adapter though as I cant find anyone else that carries the fitting in a -12 AN.
Alternatively if you wanted to use both of KO's adapters the parts list would look something like this.
-3 AN Oil Feed Line:
-NOS-17955NOS Fitting, Straight, -3 AN Male to 1/4 in. NPT Male, Aluminum, Blue anodized
-EAR-600103ERL Fitting, Hose End, Speed-Seal, Straight, -3 AN Hose to Female -3 AN, Steel, Zinc Plated
-EAR-609233ERL Fitting, Hose End, 90 Degree, -3 AN, Speed-Seal, Aluminum, Red/Blue anodized
-EAR-303003ERL Hose, Auto-Flex, Braided Stainless Steel, -3 AN, 3 ft. Length
Some other food for thought - if you are looking for a replacememnt banjo bolt for the GEN 3 3SGTE again Earl's Performance Plumbing has this one:
-EAR-997591ERL Banjo bolt, 12mm x 1.25, Aluminum, Blue anodized
If you are purchasing the Rabidchimp oil line kit and need the reducer/adapter for the KO oil return fitting this is the part:
AER-FBM2422 Fitting, Flare Reducer, Female -12 AN to Male -10 AN, Steel
If you are purchasing the Rabidchimp oil line kit and need the -10 AN oil return fitting this is the part:
http://www.jpautoworks.com/toyota_mr2.htm
Additionaly they also sell a -4 AN oil feed adapter for the gen 2 3SGTE block.
Im still looking into what it it will take to make a oil feed fitting for the Gen 1 3SGTE block but I should have a solution in a couple of days.
Im still waiting on the turbo oil flanges to be made, my machinist is making me a sample piece now. However you could use your stock turbo oil flange...requires you to cut the existing line off and tap the holes to the correct thread of the fittings that you use for oil feed/return.
Last edited by allblackalltrac on Wed Aug 30, 2006 7:45 pm, edited 1 time in total.
allblackalltrac
Postby 88st165 » Sat Aug 26, 2006 7:20 am
wow good work. its nice to see someone take some initiative and create a parts list and everything especially for our community which we all know sometimes doesnt have many options if any at all.
here was my parts list from summit:
AER-FBM1120 (90 Degree, -3AN Hose to female -3AN $9.88 )
EAR-800110ERL (Swivel Seal, Straight, -10AN Hose to Female -10AN $10.25)
EAR-935112ERL (Coupler, 90 Degree, Female -12AN to Female -12AN $20.75)
EAR-991920ERL (Union Reducer, Male -12AN to Male -10AN $10.95)
Black st165 - gone
88st165
Images: 2
Postby allblackalltrac » Wed Aug 30, 2006 7:58 pm
Hey guys after further discussion with some of my peers it was concluded that a -4 AN line and a 1/8 NPT is better suited than a -6 AN line with a 1/4 NPT.
That being said I edited my above post to include the -4 AN line with a 1/8 NPT fitting.
Not only will it provide better oil pressure but it makes the whole kit alot cheaper with less parts.
Also I included a -10 AN oil return adapter I found that would work with Rabidchimps oil line kit without having to buy an adapter for the KO -12 oil return fitting. As well as a -4 AN oil feed adapter instead of a -3 AN fitting. The -10 AN oil return adapter and -4 AN oil feed adapter is sold by JPAutoworks.com
allblackalltrac
Postby klue » Fri Sep 08, 2006 4:35 am
Ok as promized i got yall pics of my set up.
So i got a few differnt things im trying.
In the pics we got are ALL AIRCRAFT QUALITY hose and fittings. Some are actually US militiary spec. So pretty much u can lift your engine out by the hose if u wanted to lol.
In there the BLUE hose is actually an Aircraft grade air condition hose capable of withstanding 400 degrees either way. and i think aroun 600 psi.
The steel braided hoses are withstand 30,000 psi. no joke. tempature is really of no concernt.
I could possibly be making kits once i get my lines sorted out so id like to gather some intrest and we will see from there. All the fittings hoses etc i get locally. no need for KO racing adapters i can get them here for cheaper and built to an higher spec. These hoses are much higher quality and built much better than any other product ive seen before.
Ill get more information once its complete. Eventually i might offer 5axis laser cut flanges, all the fittings, and hose made to your specs.
once mine is done i will get back a approximate price and neccessary hardware.
cheers
Postby hacker_720 » Fri Sep 08, 2006 1:05 pm
Luke, how much did that cost you?
And for sure everyone it right, the hardest part is the oil lines. you can mod the first gen oil line and try and make it work, but somehow it always fails. I also would like to get in on one of these kits, be it Lukes or Dannys. In case any of you thought this was expensive, I went to Toyota and asked about the oil feed/return lines. The small one (the 6" on with the crinkles) was $248.00 and the large return line was $275 (+/- a couple of bucks) so $500.00 for the stock line that doesn’t fit, that you have to grind and screw around with, and it will probably leak when you are done. Right now I have rubber lines on mine and they are leaking, I have two hose clamps per end and they still leak. We definitely need these kits.
hacker_720
Postby klue » Tue Sep 19, 2006 7:30 pm
UPDATE :
well ive spoken to a guy about the laser cutting. its going to be around 60 dollars for EACH flange alone so lets brake down the pricing and see who is intrested.
THESE ARE APPROXIMATES the more intrest possibly the lower price
Flange alone = 60
fittings = around 10 each needed atleast 4. ( i can get custom hoses made)
hose around 40 each ( need 2)
90degree elbow = 10
block adapter is 5 dollars
pan adapter around 5 aswell
JUST so u know i get the EXACT same adapter for block and pan with the same zinc plating for 5.87 EACH, thats canadian. so...........
so around 200 dollars a kit. i know this is expensive but if u care ull get it. please post weather or not your intrested. and please not that im not making anything off this so your gonna have to pay your shipping aswell.
-xiiimotorsports
Postby 88st165 » Wed Sep 20, 2006 2:39 am
thats cheap! i paid $100 alone for the block adapter and oil pan adapter.
Black st165 - gone
88st165
Images: 2
Postby hacker_720 » Wed Sep 20, 2006 11:36 am
Yup. I'm still in.
Like I said before it's like $300.00 for new stock, so we are still ahead of the game.
do we need to buy the lazered plate if we have our own, or dose the plate include the fittings already welded/tapped on it?
hacker_720
Postby klue » Wed Sep 20, 2006 7:38 pm
well im getting just the flange alone. im going to have to tap it and do the fittings on my own, or i could just ship it out and let u do it. i will however assemble the lines, because any idiot cant do that. there is a special techinician that does it
