JDM ECU and Greddy E-manage
Postby 91redst185 » Fri Oct 01, 2004 11:23 am
I have the US ecu and im going to be getting the Greddy E-manage. Is it better if I get the JDM or just use the one i got. It is a piggy back, and the JDM one has better spec already. just want to know which would be better or if the JDM one even works. thanks
91redst185
Postby CMS-GT4 » Fri Oct 01, 2004 1:08 pm
On the note of the JDM ecu. I would only concider using it if it was damn cheap. All it is going to do is give you a slightly higher baseline. You modifying the ecu signal anyway. So you may not notice a difference once you tune the engine.
There was a post on the mr2 oc board about using the ecu w/o any tuning making more power when adding a turbo or fuel, but you are tuning it and should end up with a close enough signal anyway. I think it would be a waste of money.
Postby 91redst185 » Mon Oct 04, 2004 12:10 pm
thanks
91redst185
