Boost Controller Boost Source for TD06
Postby enzytebob » Sat Oct 02, 2004 3:50 am
How did you guys w/ TD06's get your boost source since the turbo has no boost control port?
I plan to drill a hole on the tmic pipe right after the turbo and install a barb fitting. Is there another alternative without having to modify the tmic or bore a hole on the turbo and create a port like the ct26?
enzytebob
Postby BraveUlysses » Sat Oct 02, 2004 4:45 am
Use a t-fitting.
BraveUlysses
Postby enzytebob » Sat Oct 02, 2004 4:55 am
BraveUlysses wrote:Use a t-fitting.
:shrug: attached to where?
enzytebob
Postby RedCelicaTRD » Sat Oct 02, 2004 8:16 am
Use a fitting on the intake manifold. This will probably be the most consistant.
Postby enzytebob » Sat Oct 02, 2004 2:09 pm
Thanks, Wayne. I do have it teed off of the boost pressure sensor right now. I was just wondering if the pressure difference pre and post-intercooler was a big deal in terms of getting an accurate boost reading and also overboosting.
The more I think about it, it seems that getting it after the intercooler seems more accurate so you may be right.
enzytebob
Postby illGT4 » Sat Oct 02, 2004 5:26 pm
Getting your source at the intake mani (post ic) is best.
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
