under turbo
under turbo
Postby omgitsroy326 » Sat Oct 02, 2004 11:30 pm
under the turbo there's some leakeage ... do you know what it is ??/ what need to be changed?
omgitsroy326
Postby Austen_gt4 » Sun Oct 03, 2004 1:37 am
165 or 185 ?? oil cooler and there is also oil lines down there.. we need more info..
2006-DURAMAX RaPeVaN
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
LOTUS 7 (in progress)
Austen_gt4
Postby omgitsroy326 » Sun Oct 03, 2004 2:32 am
it's a 165... i jus put my hand right under the turbo... what should i look for ?
omgitsroy326
Postby Austen_gt4 » Sun Oct 03, 2004 4:05 am
air or fluid leaking.. still need more info.. there is an oil cooler that has copper o rings and the lines that go to that could be leaking.. still need more info..
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
Austen_gt4
Postby Shaggz00 » Sun Oct 03, 2004 5:07 am
you might also want to check the plastic(rubber?) intake piping right there on the turbo. mine has a crack in it and leaks oil from the whole blowby thing(I really need a catch can).
On a seperate note, how much oil should really be blowing through there? cuz it seems when I go on a long trip(like 400 miles) I need to put a whole quart of oil in. I dont have any oil leaks anywhere else.
-Avi-
Shaggz00
Postby gpmarzan » Mon Oct 04, 2004 12:01 am
Shaggz00 wrote:you might also want to check the plastic(rubber?) intake piping right there on the turbo. mine has a crack in it and leaks oil from the whole blowby thing(I really need a catch can).
whoa! 1qt in 400 miles?? i went from NJ to VA beach (mapquest-341miles) and i lost about 1/3 of oil. that was when my turbo oil seals were still good. now i would lose about 1/4 of oil if i drive hard for about an hour (30-50 miles)
gpmarzan
