Blue_GreyST185":2dbl82tf said:I think Wolfkatz is doing a GP on fuel rails at MR2OC also :lol:
He is - its like 2 down from the Chris K one.
I asked Chris some questions about fitment on there - we'll see what the answer is.
Zeus":34badpiw said:Dave i like your set up
Griffin":3tp6nm9c said:Yeah - that was kind of the plan - start with building the engine - get that worked out - get the EMS cams pump and injectors on - get that worked out - Brakes and suspension, then crank the boost and get the FMIC on - get that worked out and tuned. (which is the step I'm on now)
after that its rollcage, finish gutting and weight reduction, 5 point harness, Racing wheel, Seats (*IF* I can afford them) then after that its a tossup between big brake kit and big turbo. Turbo is more expensive, and will require new injectors, but probably is worth it.
Please let me know how that GT30 works out when you get it on - if it spools as fast as I think it will I have a feeling I may be getting one.
illGT4":2xwwle8o said:What kind of brakes did you get Dave? I'm looking to do that when I put this next groccery list of mods... I was thinking the Rockateer bbk.
Thanks for the help!
illGT4":1araphho said:What kind of brakes did you get Dave? I'm looking to do that when I put this next groccery list of mods... I was thinking the Rockateer bbk.
