Silly Idea... I think...
Postby Gary » Tue Oct 05, 2004 3:44 am
If your car caught on fire, you are pretty fucked, with or without NOS. :wink:
93 ST185
Gary
Postby furpo » Tue Oct 05, 2004 3:49 am
a nos bottle should have a shut off on it similar to how a fuel pump realy is set up. ie turns off when the engine stops. the nos bottle its self is very unlikly to leak aswell even in a fire. if a fire happened i would be more worried about the fuel tank or battery than nos. in short if it is done properly there is no problem. if you think you can hold the bottle in your lap along with a fuel cell you will have a problem. i tryed to do a quick search just know on yahoo and nothing came up so it carn't be a big risk.
roger
furpo
Postby toayoztan » Tue Oct 05, 2004 1:47 pm
Gary wrote:If your car caught on fire, you are pretty fucked, with or without NOS. :wink:
Witty lol.
But back to the subject that got off subject :wink: Furpo mentions adding X amount of power, but it's not THAT much power...so how much power are we talking? I know it all depends on the application, the amount of shots, etc, but i'm just looking for an average or perhaps a maximum. I see all these people throwing on NOS and claiming their car is fast, so i'd like to get a little more factual information rather than just tell them they're retarded for not reinforcing their engine in the first place. I don't know much about NOS, but I always found it cheap. Please no flamming me on that, but one day I may think of why it's cheap haha. Thanks!
Bryan
Oh, and i know NOS is a brand...but i got lazy and said NOS anyway instead of nitrous oxide :P
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby furpo » Tue Oct 05, 2004 2:13 pm
i have said about all i know on the subject.
david vizard has brought out a book on nitrous oxide. i would start by reading that if i was to use it.
roger
furpo
Postby alltracman78 » Tue Oct 05, 2004 3:14 pm
SnowDRiFT wrote:guns dont kill people, dangerous minorities do!
same applies to nitrous and stupid ricers who dont know what they are doing....
:rofl:
word
Postby alltracman78 » Tue Oct 05, 2004 3:21 pm
toayoztan wrote:But back to the subject that got off subject :wink: Furpo mentions adding X amount of power, but it's not THAT much power...so how much power are we talking? I know it all depends on the application, the amount of shots, etc, but i'm just looking for an average or perhaps a maximum. I see all these people throwing on NOS and claiming their car is fast, so i'd like to get a little more factual information rather than just tell them they're retarded for not reinforcing their engine in the first place. I don't know much about NOS, but I always found it cheap. Please no flamming me on that, but one day I may think of why it's cheap haha. Thanks!
You answered yourself. It's just like asking "how much hp will a turbo add to my car?"
All NOS is is extra oxygen. You can add small amounts to any engine with no ill side effects, as long as it's set up properly. Just like a turbo.
Postby furpo » Tue Oct 05, 2004 3:28 pm
i think what toayztan is asking is how much hp will say a 50hp give you. it will not be 50hp. it will be something like 40-45hp because you are not burning the fuel at (sychromic sp?) ratio. it is burned much richer so there is some fuel in there that is taking up volume just to cool the charge and also there are other reasons why it will not make 100% of the 50hp.
how much less will it make i don't know. i guess it depends
roger
furpo
Postby MrWOT » Tue Oct 05, 2004 4:13 pm
furpo wrote:yes it is dumb. then again i am prepared to fix things. i launch my car off the limiter with my foot flat to the floor. i don't make a habbit of doing it. i don't race the gt4 very often. i have a mini that i race.
i had a similar idea to you a while ago but instead of an electric motor i was going to use a two stroke engine to run a blower till i found out how big the engine had to be. well done on thinking out side the box. every now and again you will come up with something that works that no one knew about.
with the nos a lot of proven cars use it for spooling a big turbo. i was suggesting it as imo a better option. just trying to help out.
roger
Building boost pre-launch is quite simple when drag racing you know. I used this trick all the time on my 86 SVO and it worked beautifully. Here's how you do it.
First you need a clutch activated switch, so then when the clutch is fully depressed it will cut the circuit, YES i mean CUT the circuit, then tie this line inbetween the spark signal from the ECU to the coil. Voila, instant complete cut of all advance when you hit the clutch, what does this mean? With the timing so far retarded, the air/gas mixture won't finish burning completely and will finish it's burn in the exhaust manifold, rapidly spooling the turbine, I used to launch at 10psi in 1st gear on my SVO 8) That's all there is to it. Can't say I'd much recommend a 10psi launch on anything but a car in excellent shape though.... 1st on the Alltrac is really steep, might break something.
BTW, it's not an exact description because on the SVO there is a SPout connector that I used, not sure where/what the connector on the alltrac looks like, I'll go take a peek later :wink:
MrWOT
Postby furpo » Tue Oct 05, 2004 4:24 pm
sounds like a very good idea. cheap anti lag. on the gt4 the ignition cheak port on the diagnostic port retards the ignition back to base advance i think so this may work if this curcuit can be used.
am i right in what i say above?
roger
furpo
Postby turbo4wd » Tue Oct 05, 2004 4:39 pm
furpo wrote: the nos bottle its self is very unlikly to leak aswell even in a fire.
i guess brian spilner had the wrong bottle then.. :D
Dan
Undercover Moderator
turbo4wd
Postby furpo » Tue Oct 05, 2004 4:43 pm
who ???????
furpo
Postby alltracman78 » Tue Oct 05, 2004 5:13 pm
:rofl:
F&F
If you have it set up correctly (cutoff switch), and the fire stays away from the bottle, it will be fine, but if the fire gets to the bottle, BOOM.
Postby killer_siller » Tue Oct 05, 2004 7:33 pm
about the electric motor pre-spooling the turbo idea
mazda is actually doing it. if i'm not mistaken their RX8 concept car actually had it on it.
that and i believe they are looking into it for the new rx7. how cool is that.
killer_siller
Postby Griffin » Tue Oct 05, 2004 8:24 pm
CodingParadox wrote:For one, I'll never ever stick NOS in my car... Far as I'm concerned, it's about the stupidest thing one could ever do.
For another, this was just an amusing idea that trickled across my head. I really don't care at all about actually implementing it.
Though I kinda wanan know how you can get 6psi free revving. I'm pretty sure I'll redline before I get any real boost. Though, I haven't tried it because free revving to redline is dumb as hell.
I make 8PSI revving at 8500 RPM :)
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
