Trans rebuild parts
Trans rebuild parts
Postby 88Allheeze » Thu Jun 29, 2006 10:55 pm
Does anyone know where I could buy parts to rebuild my trans for my st165? Im gunna need atleast syncros. Has anyone heared of double syncro kits for toyota trans?
88Allheeze
Postby BoostedBlueToyotas » Thu Jun 29, 2006 11:01 pm
Well, ....., from Toyota :D
For the ST185 there was no kits, you ordered each part seperately. I ordered every bearing and synchro, shift fork, and it was in the neighborhood of $800 (discount).
Here was my original list (I didnt need the gears and some other stuff)
Figure 3305
33321N - 90366-32002 - $61.06 - Front output shaft bearing
33311A - 90365-30023 - $42.25 - Front input shaft bearing
33335C - 90364-39008 - $21.13 - needle roller bearing for 1st gear
33367 - 33367-20040 - $26.75 - (2) synchro ring #1
33332B - 90364-39006 - $19.80 - needle roller bearing for 2nd gear
33333A - 90364-36007 - $16.13 - 3rd gear bearing
33321A - 90366-28007 - $47.71 - rear output shaft bearing
33428C - 33428-20060 - $66.94 - 5th gear driven
33368 - 33368-20040 - $23.95 EACH - (2) synchro ring #2
33334A - 90364-36010 - $15.02 - needle roller bearing for 4th gear
33311E - 90363-33007 - $17.82 - input shaft rear bearing
33336A - 90364-33004 - $21.45 - needle roller bearing for 5th gear
33336 - 33036-20050 - $106.16 - 5th gear
33335 - 33032-20070 - $136.85 - 1st gear
33369 - 33369-20010 - $21.11 - synchro ring #3
33423A - 33423-20020 - $79.52 - 3rd gear driven
33422B - 33422-20030 - $66.94 - 4th gear driven
33332 - 33033-17010 - $119.52 - 2nd gear
Figure 4301
33449 - 33449-20010 - $8.58 - magnet
41311E - 90366-57001 - $29.73 - front diff case front bearing
31105D - 90311-30006 - $5.04 - oil seal, front trans case
41311F - 90366-50014 - $61.06 - front diff case rear bearing
Figure 3302
33111Q - 90311-50027 - $10.07
Figure 3609
36106F - 90301-99049 - $2.80 - O-ring
36109A - 90301-63005 - $2.22 -ring
36115C - 90311-38032 - $6.92 - transfer ext housing seal
36113A - 90311-47003 - $13.43 - transfer case RH oil seal
36114B - 90341-22001 - $5.02 - plug #1
Figure 3307
33275F - 90341-12004 - $2.26 EACH - (3) plug, shift detent ball
33261C - 33261-12060 - $121.91 - select lever shaft
33211 - 33211-20020 - $29.29 - reverse fork
33212A - 33212-20060 - $36.05 - #1 fork
33213G - 33213-20043 - $26.05 - #2 fork
33214G - 33214-20031 - $22.11 - #3 fork
33584A - 33584-20020 - $0.96 - control shaft gasket
Figure 3610
41201L - 90366-32004 - $31.35 - Transfer pinion rear bearing
41201K - 90366-40105 - $38.79 - Transfer pinion front bearing
41301H - 90366-58001(RH) 90366-55022(LH) - $29.73 EACH - (2) ring gear
case bearing
41335D - 90365-44006 - $29.87 - side gear bearing
Figure 3611
36302A - 36302-20010 - $26.47 - lever, shift asseb #1
41462E - 41462-20020 - $17.96 - diff lock shift
36114D - 90341-12004 - $2.26 - plug
36307A - 90313-14001 - $2.10 - oil seal
41462D - 90311-14005 - $4.14 - oil seal
Total - $1525.08
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby grip addict » Thu Jun 29, 2006 11:41 pm
don't you need a press to put everything back in?
i need to warn everyone-
grip addict
Re: Trans rebuild parts
Postby jwgt41 » Tue Feb 14, 2017 7:34 pm
Tim, did you use all the parts on your rebuild? I'm looking for a 36302-20010 lever assy
1990 Toyota Celica All-Trac
2001 Toyota Solara
2003 Subaru WRX
2005 Toyota Tundra
2011 BMW 335iX
jwgt41
Users browsing this forum: Baidu [Spider] and 5 guests
