Straight Intake
Postby goldfish » Thu Oct 07, 2004 5:32 pm
Try something out as this is what i noticed.... if i am sitting in traffic, or just have the car parked while i run into the store - then the intake pipe gets hot because the air around it wams it up. Now, run you car - hard even, and immediately get out and touch the pipe - mine was cool. So, in my opinion, the main gain is for when you are sitting and not running enough air through it to keep the heat out. Ceramic coating may be good, but i tend to lean towards actual heat shielding like the thermotec heat wrap that is on my intercooler pipes. It's not as bling though...
Aluminum will transfer the heat fast - so even if you dont wrap it , it will probably get cool within the first couple minutes of actual driving. I want to wrap it for overkill :-D and I also just plan on wrapping the AFM as well becuase that has a lot more mass to store more heat which would take longer to discipate when driving again.
Just my thoughts and ideas....i'm no expert
David G.
'91 ST185
goldfish
Postby alltracman78 » Thu Oct 07, 2004 5:37 pm
goldfish wrote:Just my thoughts and ideas....i'm no expert
Sound advice just the same.
Postby BraveUlysses » Thu Oct 07, 2004 8:55 pm
Here's my fender-mounted CAI.
BraveUlysses
Postby Doge » Fri Oct 08, 2004 2:53 am
Ghetto... yet effective 8)
Doge
Postby enzytebob » Fri Oct 08, 2004 2:14 pm
very creative setups :)
I still have my stock crooked intake :( with an HKS air cleaner sitting just aft of the strut tower inside the engine bay. I always wondered if it was possible to reverse the position of the vent just above it so that it would act as an air intake to suck in even more air and help the stock intake duct which I have aimed at the air filter element Has anyone done this?
enzytebob
Postby BraveUlysses » Fri Oct 08, 2004 4:07 pm
enzytebob wrote:very creative setups :)
People have done this but it is not helpful. Those vents are there to help evacuate the underhood heat, not to pull air in. Furthermore, it seems likely you would be pulling in water and more debris towards the filter, which is never good.
BraveUlysses
Postby -==L=a=N=c=E==- » Tue Oct 19, 2004 2:41 am
Project Straight Intake
Well the guy down at the local engineering shop finished up with my intake. I have to say one of the best jobs ive seen. Cost me $44 all up, but i can justify it. Pictures speak my words.
The garden hose is temporary, and i havn't fitted back my original intercooler, with the welded on port. But we'll see how it goes. I need to buy some 1/2" tubing to finish it off.
The difference in my quick drive was staggering. Faster Spool, Louder Intake, and Higher boost, 1Bar set on the eBoost is now reading around 1.05Bar.
-==L=a=N=c=E==-
Postby OlyST185 » Tue Oct 19, 2004 3:26 am
those hoses are water hose for the house keep up isnt it? :doh:
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby -==L=a=N=c=E==- » Tue Oct 19, 2004 5:47 am
OlyST185 wrote:those hoses are water hose for the house keep up isnt it? :doh:
yes, yes they are....
This is the finished product.
-==L=a=N=c=E==-
Postby Conrad_Turbo » Tue Oct 19, 2004 6:06 am
This is my setup (Optima Red Top relocated to the passenger side of the trunk):
http://ace.tupeck.com/images/105_0585.jpg
I have more pics...I just need to find them.
Conrad Andres
Mint Design
mint-design.ca
Conrad_Turbo
