FMIC Problems
Postby etantshi » Tue Feb 13, 2007 7:14 am
alltracst185 wrote:ya so i finaly got the bov installed and it still has a very slight shutter,enough to drive me crazy :twisted:
i've put my air flow sensor mounted straight again.
and installed a hks ssq bov.
do u think i should try to adjust the bov? :shrug:
has anyone figured out the cure for the shutter?and if so on what year all trac?
You can't adjust the hks ssqv in the sense of making it more sensitive to open under an off throttle condition.
The only adjustment you can make is to adjust the screw to hold the bov closed if vac is strong enough to keep the bov open at idle.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby alltracst185 » Tue Feb 13, 2007 5:04 pm
so what can i try to get rid of the shutter.do u think i have a boost leak somewhere?how can i test for that?
alltracst185
Postby alltracst185 » Sun Apr 08, 2007 8:39 pm
did anyone find out how to completely get rid of the shutter from the bay area front mount kit when your off the throttle?
alltracst185
Re: FMIC Problems
Postby loudstealthGT-Four » Fri Apr 25, 2014 8:09 am
I've had the same shutter since I put my FMIC in (3 years ago), have tried a few things. But its still there, have just learned to deal with it :shrug:
loudstealthGT-Four
Re: FMIC Problems
Postby Mafix » Mon Apr 28, 2014 7:13 pm
I fixed mine. haltech ps1000.
