mild steel exhast manifold
Postby Qlynxer » Sat Oct 09, 2004 11:59 pm
I'm getting a custom exhaust manifold made and i was wondering what materials would be up to the task. I dont care much for looks, as long as its functional. Would mild steel be a good choice? It happens to be cheap. Can it handle the heat? If not, what would you guys reccomend?
Thanks Quan L
Santa Ana Ca
Qlynxer
Postby tim » Sun Oct 10, 2004 3:45 am
I guess it depends on what your power goals are. The simple fact is that the stock Toyota manifold flows very, very well. If your goals are under 300hp, you really don't need a tubular manifold. Beyond 300hp....then you'll probably want something a bit more substantial.
Tim
Aussie Exhaust - USA
www.aussie-speed.com
tim
Postby furpo » Sun Oct 10, 2004 8:22 am
i have use boiler tube in the past to make extractors. i find it strong, cheap, easy to wield and it also comes in mandrill bends. i have never made a turbo manifold though.
roger
furpo
Postby Qlynxer » Sun Oct 10, 2004 3:28 pm
My power goals are within 300hp, so the main reason i'm getting this manifold made is to fit a new turbo on. I was going to have an adapter plate made, but then i figured I'd go with new manifold.
Santa Ana Ca
Qlynxer
Postby tim » Sun Oct 10, 2004 3:41 pm
If you can get away with an adapter plate, do it. It'll be cheaper, just as effective under 300hp and easier to get made.
Tim
tim
Users browsing this forum: Baidu [Spider] and 3 guests
