bov question from an idiot
Postby XoDuzZ » Wed Oct 13, 2004 4:25 am
think i could stick one of these on astock top-mount intercooler if i get it welded on?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 71411&rd=1
1990 White Toyota Celica All-Trac.
Whiteline RSB, TRD Adjustable Struts,
TIEN Camber plates, MBC, Intake,
Short Throw, JDM ECU+Engine,
Redone System 10 with Kicker RMB8's,
Polk Audio Tweeters, Dash Speakers,
and Rear Mid-Woofers.
XoDuzZ
Postby Fat Trac » Wed Oct 13, 2004 4:48 am
i have one on my car. its a tight fit, but its there. it is rubbing on something on the bottom of the hood though...
Fat Trac
Postby XoDuzZ » Wed Oct 13, 2004 4:55 am
think it would fit if i put it on sideways?
btw - does it have a nice sound? like not defening to the driver loud but civic sititng next to you oh shit i'm scared loud.
XoDuzZ
Postby RIalltrac » Wed Oct 13, 2004 1:03 pm
I would just make sure that it comes with an aluminum mount to weld to your intercooler. Other than that you should be good to go, just weld it to the bottom of the intercooler on the right near the inlet from the turbo pointing down a little. I've seen a lot of people weld there with good results.
Chris - 90 ST185
RIalltrac
Images: 2
Postby shoteh » Wed Oct 13, 2004 2:50 pm
this might be a dumb question but I bought the samco t hose and the universal ssqv but now I dont know what to do. do I still need to buy the flange and if I did how would connect the t hose to it. does anyone have any pics of the ssqv and the t hose. Ive only seen welded ones not the t hose yet. 935 hasent replied also
-Shia-
-91 pink st185 - SOLD
-91 Pink st185 - SOLD :(
-90 Gray st185 - Recently Sold
-94 celi beater - current driver
-What's next B5 S4 ?
shoteh
Postby AWDios » Wed Oct 13, 2004 3:56 pm
Yeah, I'd probably just go with the T-Hose, it could be a long wait to get it, but I think you'll run into less possible problems then welding.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby Gary » Wed Oct 13, 2004 4:56 pm
Not on ST185 but you get the idea.
93 ST185
Gary
Postby shoteh » Fri Oct 15, 2004 4:29 am
Ok heres what I have so far...
would this be what I need?
Image(sorry pix just for show)
and after I put the flange on the bov what would I need to connect the hose to the flange? Do I just stick it in the hole of the flange and leave it there? :shrug:
also some people says that there might be a performance difference between using the t hose and welding it on...does anyone know if there is?
-Shia-
shoteh
Postby alltracman78 » Fri Oct 15, 2004 1:33 pm
I think you're missing a part.....
The part that inserts into the hose....
You'll need a clamp too, or you'll blow it off.
Dont think there's any real performance difference between welding and the hose :shrug: .
Postby shoteh » Sat Oct 16, 2004 3:05 pm
ahhh this is what I needed...
also when I put the t hose on theres not much room for air to go into the hose and to the bov because when measured the ic pipe from the turbo theres only like one quarter to half inch of space between that means the Im only letting that much air go to the bov...is that what's supposed to happen? or can I do anything about it?
-Shia-
shoteh
Postby AWDios » Mon Oct 18, 2004 4:14 pm
I'm of the opinion that it shouldn't really matter where or how it's installed. When the Intake path has pressure, it should fill the whole path, including whatever leads to the BOV. When pressure exceeds the amount the BOV will hold, it blows off.
www.pstoc.org
AWDios
Postby Gary » Mon Oct 18, 2004 4:28 pm
Nope, not like that.
When it detects the vacuum change at the vacuum source, (behind TB), it vents off the pressure from the intake route (between turbo and TB)
93 ST185
Gary
Postby alltracman78 » Mon Oct 18, 2004 8:32 pm
It's a combination of both that opens the valve. The vaccum on one side pulls the valve, while the boost pushes it open.
