Advantages on supra turbo ct26 over alltrac ct26?
Postby smog7 » Thu Nov 02, 2006 7:36 pm
Is the supra turbo ct26 any better then the stock one in the alltrac? would it be wiser to just rebuild the one in the alltrac or look for a supra one? can the supra turbo be simply bolted in without any other modifications?
-omar
rally tarmac 1990 st185
smog7
Postby grip addict » Thu Nov 02, 2006 10:51 pm
it will bolt up to a 165 manifold, but not a 185 manifold. it has a larger exhaust housing and wheel, so it'll make more power, and not choke off as fast as the alltrac/mr2 ct26
if you're lookin for a small turby upgrade while still staying on stock fuel, i think this is a good go.
i need to warn everyone-
grip addict
Postby smog7 » Fri Nov 03, 2006 1:21 am
so i wont be able to use the stock manifold on my st185??? will i have to buy an aftermarket one to make it fit??
-omar
smog7
Postby MrWOT » Fri Nov 03, 2006 1:46 am
It will bolt up to the manifold, but it won't bolt up to the 185 downpipe.
MrWOT
Postby smog7 » Fri Nov 03, 2006 1:49 am
so a new downpipe will be needed?
-omar
smog7
Postby jlspec » Fri Nov 03, 2006 2:29 am
If you have a 185 then just get your ct26 upgrade as the twin entry manifold is better then the ones found on the St165 and MA70 supras.
jlspec
Postby smog7 » Fri Nov 03, 2006 2:35 am
around how much of a price would it be to rebuild the ct26 on my st185 then?
-omar
smog7
Postby 5speedGT4 » Fri Nov 03, 2006 2:48 am
Honestly, the butt dyno hardly noticed any changes in power with the supra ct26 on a stock 165 at 15psi vs the stock ct26 at 15psi. Spool up was slightly better, and it didnt fall off as soon. Hardly worth it though.... get a CT27 upgrade...
Andrew
ST165<----Sold
5speedGT4
Postby smog7 » Fri Nov 03, 2006 3:18 am
im on budget though..........
-omar
smog7
Postby grip addict » Fri Nov 03, 2006 3:45 am
are you sure it will bolt up to the manifold, the 165 and supra ct26's aren't twin scroll like the 185 is
grip addict
Postby Gary » Fri Nov 03, 2006 4:32 am
alltrac7 wrote:im on budget though..........
Do like me, "wait" :lol:
93 ST185
Gary
Postby smog7 » Fri Nov 03, 2006 4:57 am
"wait?"
-omar
smog7
Postby syko says » Fri Nov 03, 2006 5:34 am
i think Gary meant like, 'be patient young padawan"
Aloha,
Evan
syko says
Postby toayoztan » Fri Nov 03, 2006 5:58 am
It will bolt up to the manifold, but the exhaust gas will leave as twin entry, and enter the turbo as single entry, if that makes sense. I think that's what mr_wot is saying.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby jlspec » Fri Nov 03, 2006 7:18 am
Getting it rebuilt and upgraded should be around $500 which is not to bad. Just sell a couple of your video games and stop eating fast food. There you go.
jlspec
