What kind of turbo is in your car?
Postby smog7 » Fri Nov 24, 2006 2:39 am
Just trying to get a feel for the different turbos out there. What do you have and what boost are you running. me-stock ct26, stock boost
-omar
rally tarmac 1990 st185
smog7
Postby gtfourever » Fri Nov 24, 2006 3:00 am
Greddy TD06 18 psi
gtfourever
Postby grip addict » Fri Nov 24, 2006 4:58 am
td06. turbo is on engine, but engine is not in car. going to be running 17 psi pump
i need to warn everyone-
grip addict
Postby hacker_720 » Fri Nov 24, 2006 12:21 pm
I'm 2nd gen stock
BOTTLE ARE FOR BABIES...REAL MEN GET BLOWN
1990 ST185 2.2Lt
hacker_720
Postby killer_siller » Fri Nov 24, 2006 1:26 pm
garrett GT2871R .64 A/R turbine housing. going to the dyno on monday!
killer_siller
Postby gt4tified » Fri Nov 24, 2006 2:26 pm
Bone stock ct26 and stock boost (gonna be squeezing every ounce of power out of that moffa soon though) :D
gt4tified
Images: 5
Postby allblackalltrac » Fri Nov 24, 2006 3:23 pm
CT26A (MA70) - HalfTrac
H1E (Holset) - AllTrac
SupraCelifragilisticexpialidocious
super- "above," cali- "beauty," fragilistic- "delicate," expiali- "to atone," and docious- "educable," the sum meaning roughly "Atoning for extreme and delicate beauty while still being highly educable."
allblackalltrac
Postby ST185pinjo » Fri Nov 24, 2006 6:26 pm
Mitsubishi Td05 EVO III big 16G.
15 psi.
ST185pinjo
Postby Gary ST165 » Fri Nov 24, 2006 6:44 pm
Turbo Dynamics MD228 CT20 hybrid: 57mm trim TO4E wheel.
> currently .0 > 1.2 bar.
>> eventually 1.6 bar when fuelling and aftermarket ECU permits.
http://www.turbodynamics.co.uk/
‘The Car In front is the Toyota fitted with the Turbo Dynamics MD228’
To fit Celica GT4’s – UK spec. & Import versions, engine types ST185M & ST205.
Hybrid turbocharger – Part No. MD228 – Stage 2 Retail Price - £950.00
Specification
1. 57 trim, specification high flow compressor wheel utilising the latest inlet
depression style blade form. (56.5mm inducer diameter)
2. C.N.C.Re-profiled compressor housing with enlarged inlet throat for maximum air flow
capability.
3. Left hand thread shaft with Inconel turbine wheel and fitted with twin hi-temp seal rings to stop oil seepage caused by large bore or low back pressure exhaust systems.
4. Modified bearing housing fitted with Group ‘A’ 360 degree thrust bearing assembly.
5. Uprated and strengthened actuator bracket for hi boost applications
6. Optional uprated actuator – choice of 10, 12 or 14 P.S.I.
Advantages:- More Power, More Torque and Less Lag
1. All prices are in Pounds Sterling (UK), net ex-works and supersede all previous prices.
2. All prices are subject to VAT at the current rate.
3. The prices listed are for turbochargers supplied on an exchange basis. If required on an outright
basis (no old unit available), please ask for quotation.
4. Turbo Dynamics Limited reserves the right to revise, change or modify part numbers, specifications and prices of listed items without notice.
5. The listing of a price for a particular part number does not guarantee availability.
ST165 turbo 4WD
Gary ST165
Postby Qlynxer » Fri Nov 24, 2006 8:49 pm
Garret Gt28rs at 15psi.
Santa Ana Ca
Qlynxer
Postby krazybyzzle » Fri Nov 24, 2006 9:55 pm
ct26, homie EAsports has ct26 housing with the t3/t4 inside is that possible?
krazybyzzle
Postby Meurz » Fri Nov 24, 2006 10:13 pm
A grey one.
Turbocelica.nl
Meurz
Postby CDN-GT4 » Fri Nov 24, 2006 10:42 pm
No Way!! Me too!
Meurz wrote:A grey one.
CDN-GT4
Postby EVcelica » Fri Nov 24, 2006 11:58 pm
ct20b running at 14 psi for high boost.
Erik
red 90 st-185
ct-20b, 3" exhaust, custom intake, fmic,
"THE" system
2005 Scion Tc "release series 1.0"
EVcelica
Postby tweekgt4 » Sat Nov 25, 2006 7:21 am
internal gated TD06... 17-18 psi
1999 Volvo V70R, Laser Blue
2001 BMW M5, Titanium Silver
http://www.brsf.net
tweekgt4
