What kind of turbo is in your car?
Postby OlyST185 » Mon Nov 27, 2006 9:10 pm
ceramic turbine really sux, always cracks.
some friend of mine breaked many of those.
for my turbo i got twin entry CT26 with T04E 54trim compressor.
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby daveryan » Mon Nov 27, 2006 9:26 pm
Ceramic CT26 here, stock boost.
As I see it, the problem with ceramics is that if it's old, develops enough play, and makes contact, it's gone. Then you just clean out the exhaust and upgrade!
1990 ST185
daveryan
Postby smog7 » Mon Nov 27, 2006 10:09 pm
so whats the general opinion on jdm swap ceramic turbines?
-omar
rally tarmac 1990 st185
smog7
Postby tw2 » Mon Nov 27, 2006 10:11 pm
Yes all JDM's have ceramic turbos. Mine has been going strong at 10psi for 90k miles since new. Poor maintenance is a good reason to go through quite a lot of them. Poor quaility oil, never chaning oil, crap going through intake and through turbo, checking for play every 10-20k miles should pick up a large proportion of disasters before they happen. And replacing them with used turbo's of similar milage without a rebuild, it wouldn't be surprising to keep going through them. But definitely runnning more than stock boost is a sure way to put pieces of wheels everywhere. I plan to run a td05 or t3/t4 or something like that for when i eventually have the necessary mods to turn the boost up.
Ceramic turbo's are fine if you want to stick to stock power levels +/- 3-4psi. I wouldn't hunt one out though, if you found one for a decent price then why not otherwise go for something better or the reassurance of getting your ct26 rebuilt with better wheels in a slightly larger trim even, or just the ct27 and call it a day.
Thomas, JDM 90 185, 06 350z
tw2
Postby abraxxa » Mon Nov 27, 2006 10:37 pm
stock CT20b, rebuilt 5k km ago
facelift ST205
abraxxa
Postby TomsGT4 » Mon Nov 27, 2006 11:26 pm
I really wouldn't say they're bad at all.
You can put down a LOT of power with one of those. Just know where to draw the line.
It's just that you'd be tempting the wrong kind of fate to pull 20psi+ on it.
First imagine the compressor wheel blowing apart in the housing.
Then imagine all of that flying into your intake at 20+ pounds of pressure per square inch.
Tom
1990 ST185
1990 Corolla SR5
TomsGT4
Postby TheAutoholic » Tue Nov 28, 2006 12:54 am
Twin entry ct26, at 5psi, when it was running. Apparently I had the sensor unplugged lol
Currently All Trac-less....
Dracov wrote:I'm firmly convinced GT-Four trannies are made from collapsed stars.
TheAutoholic
Postby Mafix » Tue Nov 28, 2006 1:17 am
full port ct-26 at 10-15 psi pending on the temperature. soon to be 16psi solid.
Postby BayAreaAT® » Tue Nov 28, 2006 2:50 pm
gt30-76r.... :D :D I'll find out soon how good it is.
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby cardude » Wed Nov 29, 2006 2:40 am
stock ct26. hopefully running 13-15is lbs soon.
or maybe supra ct26 in my near future.
88 Alltrac
91 zx600
81 kz1000
87 4runner
cardude
Postby SeanGTS » Wed Nov 29, 2006 3:48 am
T3/T04E Garrett 54 Trim .60AR
Master Swapper
SeanGTS
Postby allblackalltrac » Wed Nov 29, 2006 9:20 pm
BayAreaAT® wrote:gt30-76r.... :D :D I'll find out soon how good it is.
Chris,
More info please. A/R of turbine and which housing did you go with? Who did you buy it from? Wastegate, non-wastegate? Did you buy it as a kit or are you peicing it together yourself? What adapter are you using? etc etc...
For me it was a toss up between the GT30R(3076) and the Holset - the Hotsex was a third of the price so I went with that but might still go with the GT30R.
SupraCelifragilisticexpialidocious
super- "above," cali- "beauty," fragilistic- "delicate," expiali- "to atone," and docious- "educable," the sum meaning roughly "Atoning for extreme and delicate beauty while still being highly educable."
allblackalltrac
Postby Denver_whiteST185 » Thu Nov 30, 2006 1:22 am
Chris,
yeah, im interested too. its kinda looks like an ATS kit...
BTW, hotsex? :shrug:
^Ted^
Denver_whiteST185
Postby allblackalltrac » Thu Nov 30, 2006 4:34 am
hoLseT = hoTseX
Its the analogy given, I didnt make it up.
allblackalltrac
Postby Hic » Thu Nov 30, 2006 5:04 am
gt30R (gt 3082) intake 0.7ar, ex 0.63ar
t04Z 0.71ex ar
both work like a charm
Hic
