What kind of turbo is in your car?
Postby d1alltrac » Thu Nov 30, 2006 9:38 am
tw2 wrote:Yes all JDM's have ceramic turbos....
Not all of them, let's not forget the ST205 WRC...steel turbine CT20B IIRC, someone correct me if I'm wrong.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby Conan » Thu Nov 30, 2006 10:40 am
d1alltrac wrote:let's not forget the ST205 WRC...steel turbine CT20B IIRC, someone correct me if I'm wrong.
You are wrong ;)
Conan
Postby silence » Thu Nov 30, 2006 11:53 am
ATS CT27 @ 16 psi
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby BayAreaAT® » Thu Nov 30, 2006 1:27 pm
Denver_whiteST185 wrote:
allblackalltrac wrote:
BayAreaAT® wrote:gt30-76r.... :D :D I'll find out soon how good it is.
Chris,
More info please. A/R of turbine and which housing did you go with? Who did you buy it from? Wastegate, non-wastegate? Did you buy it as a kit or are you peicing it together yourself? What adapter are you using? etc etc...
For me it was a toss up between the GT30R(3076) and the Holset - the Hotsex was a third of the price so I went with that but might still go with the GT30R.
yeah, im interested too. its kinda looks like an ATS kit...
BTW, hotsex? :shrug:
this is a Extremeboost kit,downpipe,oil lines,water lines,addapter. The turbo is from ATPTURBO.com GT30-76rWG 86AR t25/t28 exh. housing. My wastegate is TAil manifols is an SSautocrap :D ,
If you need more info about the turbo, go to atpturbo.com
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby turbo4wd » Thu Nov 30, 2006 2:11 pm
SeanGTS wrote:T3/T04E Garrett 54 Trim .60AR
Same here
It'll be used for the built engine..
The stock engine thats currently in the car has the stock turbo..
Dan
Undercover Moderator
turbo4wd
Postby applor » Sat Dec 02, 2006 7:17 am
GT3076R with a custom exhaust housing (high flowed T25/28 0.86 A/R machined to fit 60mm turbine)
applor
Postby d1alltrac » Sat Dec 02, 2006 7:45 am
You are wrong ;)
i read it on mr2oc somewhere and just assumed it was right :oops: , but where did the steel wheel ct20b's come from then?
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby Conan » Sat Dec 02, 2006 8:29 am
d1alltrac wrote:i read it on mr2oc somewhere and just assumed it was right :oops: , but where did the steel wheel ct20b's come from then?
At least from Euro spec ST205s.
Conan
Postby tw2 » Sat Dec 02, 2006 8:56 am
I know a lot of mr2 people get them rebuilt which would obviously be in steel. Possibly steel ones come from USDM 94+ mr2's?
Thomas, JDM 90 185, 06 350z
tw2
Postby Gary » Sun Dec 03, 2006 4:07 am
All USDM MR2 turbo (91-95) come with CT26, not CT20B.
93 ST185
Gary
Postby QIK_GT4 » Mon Dec 11, 2006 7:43 am
JDM ct26 with ceramic turbine... at 10psi
The Car:Black JDM 1990 ST185
The Mods: Whiteline Rear-sway-bar, K&N Panel, 3" Dump, HKS BOV, 2" Boost Gauge, Garret TMIC, TWM Short Shifter, Mirror Tints
QIK_GT4
Postby killer_siller » Mon Dec 11, 2006 1:19 pm
applor wrote:GT3076R with a custom exhaust housing (high flowed T25/28 0.86 A/R machined to fit 60mm turbine)
how's your spool? top end? basically; how do you like the turbo?
killer_siller
Postby MightyAl » Wed Dec 13, 2006 1:22 pm
20g on it now
GT35R is sitting in a box and keeps taunting me
MightyAl
Postby killer_siller » Wed Dec 13, 2006 3:07 pm
MightyAl wrote:GT35R keeps taunting me
as a GT35R should
killer_siller
Postby muneo » Wed Dec 13, 2006 8:39 pm
CT26 w/ 46 trim
It actually has a noticable kick to it compared to stocker without an increase in lag at all. It still falls off in the upper RPM ranges like the stocker though since the exhaust isnt clipped
Ex-185 Owner
muneo
