What kind of turbo is in your car?
Postby smc252 » Sat Dec 16, 2006 4:33 am
GT3071R; best turbo I have ever used.
Currently redoing the head to flow more air, but when I was running 8-10psi she pulled much harder then the 60-1 at 16psi and I had the turbo spooling about the same as a CT-26! Will up boost to 16psi then 20psi, should see around 400hp!
(I've had .63 a/r 60-1, 60-trim t3/t4, CT-26 all on the same engine, and none compare. I get spoolup FASTER then the .48 a/r 60-trim and more power then the .63 a/r 60-1 MUCH sooner.)
I have driven many other 2L turbo-charged cars, as a former performance mechanic, and this is hands down the one that puts the biggest smile on my face. When I tune my SMC, I will post dynos for sure.
1988 All-Trac
(Rotting away, fiending for a tranny.)
1986 Celica GTS
(GT3071R forced 3s-gte + autronic smc)
smc252
Postby gearhead313 » Sat Dec 16, 2006 11:23 pm
smc252 wrote:GT3071R; best turbo I have ever used.
I find this interesting. I've never been fond of that turbo b/c of where the efficency island lays. Granted it will spool better than a std. .48a/r anything b/c its ballbearing. I just worked with an evo VIII with a 3071r, tuned to 11.1-11.8 a/f at 21 psi... I honestly think that my alltrac at the same psi would take it... it just didn't have the torque... i dunno.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby Smaay » Tue Dec 19, 2006 3:37 pm
i wanted to go GT35R also, but after installing this 62-1 P-trim in my Supra. im going with that. spools instantly and cheap. less than half a GT35R would be. but i still love having my 35R on my boosted 7th gen celica.
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Postby gt4tified » Tue Dec 19, 2006 6:31 pm
Smaay, you went with a single turbo setup or am I missing something? That gives more juice than the twin ct20's? Yikes!
gt4tified
Images: 5
Postby Gary » Tue Dec 19, 2006 6:35 pm
twin CT12, not CT20.
93 ST185
Gary
Postby gt4tified » Tue Dec 19, 2006 8:07 pm
Gary wrote:twin CT12, not CT20.
I thought the twin ct12's were only on the 1JZ-GTE and the 2JZ-GTE carried something bigger?
gt4tified
Images: 5
Re: What kind of turbo is in your car?
Postby NoMan » Fri Nov 29, 2013 2:10 am
Stock CT26 running at ~13psi.
NoMan
Postby warracer » Fri Nov 29, 2013 2:58 am
IHI VF28 ball bearing turbo out of a Ver5 22B , its just crazy, spool up time is ridiculously short and pulls hard...
but I sent it for rebuild
Currently I run a TD04L out of a 05' WRX, It spools great, 2200rpm-2600rpm @ 18psi , pulls waaaaay harder than the CT26.
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby Mafix » Sat Nov 30, 2013 10:54 pm
pte5858 e cover .63 a/r all vband (w/ 46mm restrictor)
it's the quietest turbo i've ever owned. my bullseye was a screamer and the ct even made more noise than this
Postby built2run » Wed Dec 04, 2013 7:13 am
46 trim t04 on a stock ct26 :(
ST165, black: parted and gone
ST165, white: sold to friend
built2run
