Engine mounts
Engine mounts
Postby Gurr » Sat Oct 16, 2004 6:41 pm
Does anyone know where I can buy some polyurethane mounts?
Me and my friend installed some on his Sunfire GT and it improved his performance(expected) and seemed to make the car much meaner sounding on the streets. I would like a set for myself now :D buy am having trouble finding them. :shrug:
Thanks for you help
White 165.
Working out the 2g head/turbo swap kinks right now. *hates wiring problems*
Gurr
Postby ChrisD » Sat Oct 16, 2004 7:30 pm
LOL
No one produces poly mounts for our cars. You can do them yourself though.
Custom custom custom custom....you'll get used to it after a while! :D
1988 ST165
1994 ST205 WRC
ChrisD
Postby BoostedBlueToyotas » Sat Oct 16, 2004 7:57 pm
And if you want to buy a set of mounts to fill , I have
a set for sale :D
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby Zeus » Sat Oct 16, 2004 8:52 pm
I thought trd made inserts
wasnt pat selling a set a long time ago?
Blake Brown
Zeus
Postby ChrisD » Sat Oct 16, 2004 9:04 pm
I think the TRD ones were complete mounts? I don't think they were inserts. If you were able to get them, I think 3 of the 4 ST185 specific mounts would work on the ST165. Fuzzy memory though...
I plan on filling my own this winter, along with my rear diff mount.
1988 ST165
1994 ST205 WRC
ChrisD
Postby Gurr » Mon Oct 18, 2004 6:12 pm
Ah, well that's not cool. Could anyone inform me on how to make my own mounts... or would the TRD ones be better?
White 165.
Gurr
Postby RIalltrac » Mon Oct 18, 2004 6:52 pm
making your own mount really isnt that hard. I made my own rear diff. mount of out of poly. I could use to do the same with my engine mounts. I used a poly compound from McCaster-Carr, I think the stuff I used for my rear diff was like a 90 shore poly, personally I think it needs to be stiffer than that, but I'm no expert on this stuff and have no idea which way to go to get stiffer(no stupid jokes) Maybe chris can chime back in on what to use. Otherwise all you really have to do is clean out the mount really well, cover any openings with the metal tape they use in plumbing applications and viola you have a mold, all you have to do at that point is pour and wait.
Chris - 90 ST185
RIalltrac
Images: 2
Postby ChrisD » Mon Oct 18, 2004 7:40 pm
I've never really dealt with polyurethane so I can't say what stuff is better than others.
1988 ST165
1994 ST205 WRC
ChrisD
Postby RIalltrac » Mon Oct 18, 2004 7:44 pm
ya thats the problem I'm running into. I used a writeup that I found a while back to do my diff mount, and its way easy to use/do. I just dont know the differences in materials. I have superpro bushings on the suspension and I think the poly I used may have been too soft to use with the poly bushings already in place. I still get a lot of bouncing back there.
Chris - 90 ST185
RIalltrac
Images: 2
Postby silverarrow » Mon Oct 18, 2004 11:03 pm
Good luck trying to find someone to get you the TRD mounts...I tried all sorts of online companies, 3 different local Toyota dealerships(TRD supplier), and Toysport. None can get them.
89 240sx
07 Versa SL
silverarrow
Postby etantshi » Mon Oct 18, 2004 11:27 pm
I filled my own mounts with polyurethane. Very easy and will only cost you about 10 dollars (of course my mounts were out of the car as well).
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby ChrisD » Mon Oct 18, 2004 11:43 pm
Or you could send them to Nuke on celica.net, and he will fill them for you. For the hassle/mess that it saves, it might be worth the cost. I will be sending mine to him soon. He's definitely a well respected member of the board. Here is a link: http://celica.net/cgi-bin/ultimatebb.cg ... 0;t=007514
1988 ST165
1994 ST205 WRC
ChrisD
Postby RedCelicaTRD » Tue Oct 19, 2004 4:41 pm
Get some 80 shore from mcmaster-carr and look for a writeup one the internet. Its way easy to do. Since ive got my 80 shore on the way i might take some pics for a very easy write up.
Heres the part number: 8644K11
If you dont go through mcmaster make sure it is a flexable poly...
Postby RIalltrac » Tue Oct 19, 2004 6:27 pm
wouldnt stiffer be better? how do you go about determining which compound has what type of flexibility to it?
Chris - 90 ST185
RIalltrac
Images: 2
Postby RedCelicaTRD » Wed Oct 20, 2004 8:57 pm
80 shore is already pretty stiff. If you use a solid mount you will get alot of extra noise and vibration into the cabin. You want a flexible type so it can actually take abuse and not just crumble up.
