Engine warning lamp problem!
Postby Klas » Sun Oct 17, 2004 9:29 am
How can I turn of the engine warning lamp?
I´ve got rid of my stock intercooler, and mounted an air to air intercooler in the front of my st165. But now I can´t get the engine warning lamp to be turned off.
Anyone know how to do that?
Thanks!
Klas
Sweden
Klas
Postby saved_1992 » Sun Oct 17, 2004 11:08 am
http://www.gtfours.co.uk/how_to/ic_cons ... nstant.htm
will have to unplug the ic pump
i am running this mod and no check engine light is on, i am running the pump though
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby Klas » Mon Oct 18, 2004 2:41 pm
I´ve got rid of my ic pump to save space and weight.
I have also tried to connect a resistance that is similar to the ic waterlevel sender to the wire, but it´s not working.
I dont know what to do next, I need that lamp to be turned of.
If anyone that have changed to a front mounted ic have had the same problem, Please help!
Thanks
Klas
Postby Gary » Mon Oct 18, 2004 2:47 pm
Before you turn off the CEL, make sure there is no other error codes stored in the ecu.
93 ST185
Gary
Postby MLracing » Sun Oct 24, 2004 5:55 pm
I have rewired the the cable that turns on the light from the ecu to a switch so i can turn it on when i want.
MLracing
Postby ChrisD » Sun Oct 24, 2004 10:03 pm
You need to connect the intercooler sensor wire at the ECU (WIN i think it is?) to ground. This will eliminate your check engine light.
1988 ST165
1994 ST205 WRC
ChrisD
