4x4 distribution,
4x4 distribution,
Postby MLracing » Mon Oct 18, 2004 5:04 pm
Hi I think that the 4x distribution in my GT4 -88 is teribble, It almost feel like an frontwheel drive. Do you guys share my opinion and is it possible to change the distribution by changing the rear diff or something???
thanks for a wonderful forum
/Martin, Sweden
MLracing
Postby CMS-GT4 » Mon Oct 18, 2004 5:11 pm
Its more weight dist. and suspesnion setup then power split. Too expensive to get the power split changed unless it is a race car.
Rear sway bar and rear lsd would help out the underrsteer a bit. Also concider better struts and stiffer springs to start.
Postby Alltracmonkey » Tue Oct 19, 2004 3:43 pm
I agree, I can't tell I have AWD unless I get the tail out. Stupid open diffs.
Alltracmonkey
Postby alltracman78 » Tue Oct 19, 2004 3:46 pm
Somebody [CMS?] mentioned if you put 25?mm spacers in the rear, it makes the car oversteer more.
Postby CMS-GT4 » Tue Oct 19, 2004 4:57 pm
I tested the spacers on a car that was already modded and had a tuned suspension. May react differently w/o any other mods. I think a rear sway bar and rear lsd are the best things that could be done for any alltrac.
Postby alltracman78 » Tue Oct 19, 2004 5:22 pm
Something else that makes a good bit of difference it the bushings for the rear trailing arms [The arm that is paralell to the body]. I had to replace mine 'cause the bolts froze up, and getting them out destroyed the stock ones.
Postby omgitsroy326 » Tue Oct 19, 2004 6:29 pm
we dont' have rear lsd? errr... hwo much are they
omgitsroy326
Postby CMS-GT4 » Tue Oct 19, 2004 7:18 pm
As for having or not having rear lsd you will have to look into that. The only stock one made was torsen, and you have to open the housing to see. If you have to buy, you can find cusco and trd for around 700usd.
Postby Maloy » Thu Oct 21, 2004 1:32 am
dont they have possi in the back? it sure feels like it when you drift a corner real hard.
88 white st165 (stripped down on jack stands)
86 AE86 corolla gt-s coupe
Maloy
Postby ChrisD » Thu Oct 21, 2004 4:47 pm
Power distribution is a 50/50 split. The understeer you feel is largely dependent on the suspension setup. A better suspension system will improve things drastically. The ST185 is known to understeer much more than the ST165. ST165 is probably more prone to oversteer. Worn suspension changes things a lot though.
Winter driving REALLY lets you know the rear is working just fine. Rear tires break loose first every single time. There's simply less weight back there. You can do donuts all day long if you like.
Upgrade the suspension.
1988 ST165
1994 ST205 WRC
ChrisD
Postby d1alltrac » Thu Oct 21, 2004 6:07 pm
chris_dittrick wrote: You can do donuts all day long if you like.
yes AWD donuts are a thing of beauty...ive heard that the understeer is a result of the weight distribution like everyone is saying, something about the engine being placed in front the front axle or close to it.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby stevieg » Fri Oct 22, 2004 4:53 pm
hehe speaking of winter driving my st165 will crab-walk down the road while on boost, torque split is fine with me :-)
steve
1989 Super Red Alltrac (current)
1987 mk1.5 Mr2 (RIP)
www.3sgtemr2.com
stevieg
Postby ChrisD » Fri Oct 22, 2004 9:58 pm
d1alltrac wrote:yes AWD donuts are a thing of beauty...
Aren't they?
1988 ST165
1994 ST205 WRC
ChrisD
Postby zblu81 » Sat Oct 23, 2004 4:30 pm
is that an all-trac doing a burn-out??? :shock:
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
3" Exhaust, RC intercooler, ATS TD06-20g, stage2 clutch
zblu81
Postby ChrisD » Sun Oct 24, 2004 1:46 am
Yeah it's nuts eh?
He's a guy from Sweden. Here's some more pics of that car if you're interested:
http://www.garaget.org/show.php?car=1769
http://www.cardomain.com/member_pages/v ... 904&page=2
He runs a 13.6 second 1/4...
1988 ST165
1994 ST205 WRC
ChrisD
