New goodie: Forge wastegate actuator.
Postby Simba » Sun Feb 18, 2007 12:47 am
Well, I was sick and tired of my stock actuator on my CT27. If the cap I had on the second port wasn't blowing off, it was sticking, or just generally being a pain in the butt.
So, off with its head, and in with the Forge actuator. It has a much larger diaphragm, better/bigger spring, and you can take it apart and service it if need be. Plus, it looks cool:
Early impressions are: It's awesome. Very consistent boost, no spikes, no creep. Highly recommended if you're trying to squeeze every last bit of response out of a CT26.
I should point out that installing it is something of a PITA, as unless you fab a bracket from scratch, you need to hack the old actuator off it's bracket. This is not fun. At all. But it can be done with a sawzall and a lot of profanity.
Lots of fast, loud things.
Simba
Postby Highway » Sun Feb 18, 2007 1:50 am
Nice........ :D
Cheers! Highway
former car....Red 91 ST185 AllTrac # 666 "SATAN"
Greddy Turbo, Blitz ECU, RC/CS upgrades....+++
now a 97 BMW 840CI...I miss the AT!
Highway
Re: New goodie: Forge wastegate actuator.
Postby Denver_whiteST185 » Sun Feb 18, 2007 3:14 am
Looks very nice simba.
Simba wrote:I should point out that installing it is something of a PITA, as unless you fab a bracket from scratch, you need to hack the old actuator off it's bracket. This is not fun. At all. But it can be done with a sawzall and a lot of profanity.
Good to know :P
^Ted^
Denver_whiteST185
Postby Conan » Sun Feb 18, 2007 7:06 pm
Where did you get it (Forge online shop?) and how much was it?
Conan
Postby Simba » Sun Feb 18, 2007 8:13 pm
Conan wrote:Where did you get it (Forge online shop?) and how much was it?
Yeah, Forge USA. It's not a stocked part, so I had to wait ~3 weeks to get it from England. It was around $200 with shipping.
Simba
Postby alltracst185 » Sun Feb 18, 2007 8:38 pm
is the ct27 better than the ct20b? i know the ct27 is the ct26 upgraded......how much does it go for?
alltracst185
Postby GT4_CR » Sun Feb 18, 2007 9:45 pm
Why does your wastegate actuator has two lines? Mine only have one.
GT4_CR
Location: Costa Rica, Central America.. that little bridge between the north and the south. ( not puerto rico)
Postby Gary » Sun Feb 18, 2007 11:24 pm
GT4_CR wrote:Why does your wastegate actuator has two lines? Mine only have one.
What turbo is yours?
Actuator on CT26 has two lines.
One is connected to the compressor housing.
Another is connected to the T-VSV.
By the way, Simba, what PSI are you running out of the spring?
I'm guessing you don't use any boost controller.
93 ST185
Gary
Postby Simba » Sun Feb 18, 2007 11:45 pm
Alltrac and MR2 CT26's have two ports on the actuator. One is for the T-VSV. Supra CT26's have one.
You have a choice of spring weight when you order it from Forge. I went with the "low" 10 psi spring versus the 15 psi spring, and yes, I use an AVC-R.
More info on the CT27 is here. There's a lot of debate as to which is better. If you can find a good one, the CT20b is probably better. Most all CT26 rebuilds, which is all the CT27 is, toss seals and bearings very quickly.
I got the CT27 under the impression that ATS would stand behind their product, and to some extent they did, but in the end they ended up blaming two turbo failures on me instead of taking care of the actual problem, and so it's a crap shoot either way.
Best advice is to get a real turbo and not waste money on CT26 rebuilds.
Simba
Postby GT4_CR » Mon Feb 19, 2007 3:05 am
I have a Supra CT26 :shrug:
GT4_CR
Postby Gary » Mon Feb 19, 2007 3:20 am
Simba wrote:Alltrac and MR2 CT26's have two ports on the actuator. One is for the T-VSV. Supra CT26's have one.
93 ST185
Gary
Postby etantshi » Mon Feb 19, 2007 3:29 am
Going to rig up a custom mount for the upgraded actuator?
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby Simba » Mon Feb 19, 2007 3:44 am
etantshi wrote:Going to rig up a custom mount for the upgraded actuator?
Already did. Note the part about sawing the old actuator off being a PITA. :P
Simba
Postby etantshi » Mon Feb 19, 2007 3:49 am
Nope, didn't see that at all. I was blinded by the bling. 8) Looks very nice.
André B.
etantshi
Postby Conan » Mon Feb 19, 2007 5:06 am
Simba wrote:I went with the "low" 10 psi spring versus the 15 psi spring
Is it able to hold 10 psi all through the redline in, say, 3rd gear?
Conan
Users browsing this forum: Galante and 5 guests
