New goodie: Forge wastegate actuator.
Postby toayoztan » Wed Oct 15, 2008 4:32 am
darthripley wrote:you can always try porting the wastegate to help keep it from spiking so bad.
it's cheaper than a DP or an external wastegate if you don't have the cash to spare.
Porting the WG usually helps with boost creep, not boost spike. the spiking can occur from the WG actuator or boost controller.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby darthripley » Wed Oct 15, 2008 4:56 am
^ gotcha i wasn't sure.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby Mafix » Wed Oct 15, 2008 12:50 pm
mine is ported out. which mind you isn't much but bigger than stock. it helped.
Re: New goodie: Forge wastegate actuator.
Postby klue » Sat Sep 27, 2014 1:30 pm
bringing this back from the dead, does anyone have a size comparison with this actuator?
Looking at using this VS a turbosmart unit
Postby Hotrodhendrix » Wed Nov 26, 2014 5:11 pm
Ha first thing I noticed was a Simba post and thought "Cool he is back" Then I notice the date lol
Postby CSAlltrac » Wed Nov 26, 2014 8:17 pm
Im running one. Ill have to snap a picture of it and post it. Its real close to the same size as stock.
Postby klue » Fri Nov 28, 2014 3:06 am
CSAlltrac wrote:Im running one. Ill have to snap a picture of it and post it. Its real close to the same size as stock.
cool thanks, working on a project could use the info
