How many PSI do you run on your stock motor???
Stock Boost
11
13%
9-10 psi
3
4%
11-12 psi
20
24%
13-14 psi
15
18%
15-16 psi
20
24%
17-18 psi
5
6%
18+ psi
8
10%
Total votes : 82
Postby T-Trac » Fri Feb 23, 2007 1:20 am
I'd like to see what pressures people have been running on their stock motors.
Please respond as follows
Year, Model, miles on motor
PSI
How many miles at this psi
mods
failures
comments
You can consider changed headgeasket as stock motor, just dont forget to list it as a mod. For all of you who have modified bottom/top ends, this poll is not for you.
Lets see what we got!!!
mine:
88, 165, 100,000
stock(6-8psi)
Its been at this pressure for the whole 200 miles that I have owned it.
intake exhaust upgraded turbo
none yet
sweet car, want to make it faster, want to know whos running what without a rebuild and what problems they have had
T-Trac
Postby cardude » Fri Feb 23, 2007 1:57 am
165
205000 miles :doh:
running 11-12 psi for 100 miles now maybe
everything is stock except boost guage and mbc
i love it and will go for more after rebuild and fuel.
88 Alltrac
91 zx600
81 kz1000
87 4runner
cardude
Postby reaper0995 » Fri Feb 23, 2007 2:15 am
been running 14psi from 120k miles to 145k miles. was going strong until i blew HG at fuel cut in 5th gear... (cold day= fast boost, oops). has hit 16-17psi but fuel cuts. will remove fuel cut next time (92k miles motor swap soon)
reaper0995
Postby db » Fri Feb 23, 2007 3:28 am
Year, Model, miles on motor 1990 Alltrac, 40,000+ on rebuilt engine
PSI 15-16 psi
How many miles at this psi 40,000+
mods Twos R Us MBC, Blitz DD BOV, Fidanza lw flywheel, CM stage 3 clutch
failures prior to this rebuild, rear main seal, and other oil seals
comments zoooooom!
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Re: How many PSI do you run on your stock motor???
Postby toayoztan » Fri Feb 23, 2007 3:38 am
T-Trac wrote:Year, Model, miles on motor
PSI
mods
failures
comments
1993, Alltrac, 205k
11-12ish (depends on temperature)
Since i've owned the car (around 25k miles ago)
SSQV BOV, XS Power DP, Motoria 3" exhaust, ACT Street Disc clutch and ACT Heavy Duty pressure plate
I've overhauled motor basically with rod bearings, all seals/gaskets, hg, hoses, vac lines, timing belt, with usual tune ups
This PSI run is without a boost controller.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby alltracshoak » Fri Feb 23, 2007 3:50 am
PSI
mods
failures
comments
90,st185,170k
8-10 psi(stock)
mods for now are hks 3'' catback
failures,none so far
comments: still waiting to smog and after that, fmic and 14+ psi.
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby donteatbugs » Fri Feb 23, 2007 4:29 am
Year, Model, miles on motor - 1990 st185 150000
PSI- 13-15
How many miles at this psi- 6000
mods- 3 in exhasut, fmic
failures- none so for
comments- still slow
donteatbugs
Postby grip addict » Fri Feb 23, 2007 6:16 am
90, 134000 on old build, 50 on new stock longblock
15/17
3 months/ 5 days
intake, exhaust/ fuel, td06, intake, exhaust, mhg & studs, ecu flash
yes/nevarrr
comments :
ran 11 psi very reliably for 9 months, then decided to up it to 15, and it died.
suggestion: don't run more than 12 on a stock motor.
i need to warn everyone-
grip addict
Postby ST185pinjo » Fri Feb 23, 2007 8:40 am
PSI
mods
failures
comments
1992, ST185CS, 186.000[KM]
15 psi
50.000[KM]
Started with MBC, replacement filter, 3"aussie, FCD.
Now: EMS, fuelrail, EVOIII and some more.
never had failures.
ST185pinjo
Postby theUNYTEDone » Fri Feb 23, 2007 11:05 am
ive been at 10.5-12psi for almost a year now.
1990st185
-3"turbo back exhaust, no cats
-N1 muffler
-2.5" FMIC, 24x12x2.5 ish?
-straight intake
125K as of now, annnd yeah.
built motor should be pushing 22 for race tune and 15-7 on daily tune.
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby gt4tified » Fri Feb 23, 2007 6:27 pm
Year, Model, miles on motor: 1992, ST185, 97,xxx
PSI: 7 - 11
How many miles at this psi: 2,000+
mods: Apexi Intake filter, 3" exhaust, SSAC d/p, turboxs rfl bov, walbro in-tank fuel pump, st205 rear (lsd) diff, NGK iridium plugs, ACT clutch & PP, racing hart lightweight 15" alloys, msd blaster ss coil, AVC-R boost controller.
failures: knock sensor
comments: hoping to tune the shit out of the ct26 soon!
gt4tified
Images: 5
Postby gearhead313 » Fri Feb 23, 2007 7:22 pm
PSI
mods
failures
comments
1988 ST165, miles on motor unknown (JDM rev2 motor)
18psi (20psi peak) for 1500-2000miles about.
swap, tubular mani, borg/IHI GM-3 turbo, tial gate, 2.5" down and back, straight intake, 2.5" piped FMIC.
Knock sensor problem for the last 500miles, have yet to fix it.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby 88st165 » Sat Feb 24, 2007 1:52 pm
1988, st165, 46,xxx mi.
on average around 12-14psi... no boost controller just open midpipe
prob about 2k mi on this psi
twin entry swap, straight intake, 3" d/p and m/p, upgraded h/e, constant pump mod....
i am planning on getting an exhaust in hopes to lower it to 10-12psi
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby Simba » Sat Feb 24, 2007 2:59 pm
'91 ST185, 2nd gen JDM engine with ~50k on it.
15 psi street (93 octane), 22 psi race/rally (100 octane).
~10,000 @ 15 pounds, probably ~750-1000 at 22.
Mods: JDM computer, tweaked base fuel pressure, Denso Supra TT pump, RC cleaned/flowed 440's (~452cc), CT27 w/ Forge actuator, BayArea 3" TMIC, SSQV, AVC-R, JUN cam gears (-4 ex. +1 in.), K&N FPIK, KO 2.5" DP, 3" Motoria, Innovative wideband. Various other crap.
Failures: Nothing so far, at least related to the engine. I did have a CT27 toss an oil seal, but ATS replaced it, because ATS rocks.
Comments: My goal with the car is to squeeze as much as possible out of a stock engine, CT26 housing and (mostly) stock fuel system, with sacrificing reliability.
So far, it's been very fun, pretty quick and given me no trouble.
Lots of fast, loud things.
Simba
Postby Qlynxer » Sat Feb 24, 2007 10:47 pm
88 165 with about 70K on JDM 2nd Gen motor.
15 psi daily driven, for over 15K now.
Mods include Garett Gt28rs turbo, 205 intercooler, Full 3inch exhaust, and just recently I installed a water injection kit. I may bump it up to 17psi for track use.
No failures, but i've had to do a lot of maintanece like radiator, axles, alternator etc.
Quick and relatively reliable, I freaking love it.
Quan L
Santa Ana Ca
Qlynxer
