How many PSI do you run on your stock motor???
Stock Boost
11
13%
9-10 psi
3
4%
11-12 psi
20
24%
13-14 psi
15
18%
15-16 psi
20
24%
17-18 psi
5
6%
18+ psi
8
10%
Total votes : 82
Postby built2run » Sun Feb 25, 2007 4:56 pm
88, st165, 1st gen. jdm w/ +-50k
aprx.16, 1.1 bar
about 10k @ 1.1
k&n oem replacement, MBC, intercooler pump constant run, bigger heat exchanger for ATW-stock core, primary cat is gutted.
no boost related failures yet, was missing because of old plugs but thats it.
this car is smooth and fast, i use Redline 20w50 synthetic oil i recommend this for all turbo cars, its designed for them.
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby at3619 » Mon Feb 26, 2007 3:20 am
94' 205 motor w/ almost 100,000 miles
8psi on winter ethanol pump gas("91 octane" :x) :cry:
18psi on 91 octane(best we get at the pump)
22psi on 100 octane
Josh
-2 Twin Super Red 88 Alltracs (RIP my sons...)
-One sweet pile of all trac parts!!!
-00 Celica GTS(B18 Eater)
-1985 Volkswagen Vanagon Westfalia Camper AKA "turtle"
Converted to Syncro(4WD)
Subaru SVX 3.3L H6 swapped!
at3619
Postby Phil-GT4RC » Sat Mar 03, 2007 11:36 am
1991 RC 86,000
15psi
20,000 and nearly 2 years at this boost
No boost related problems, general wear and tear parts only
Blitz Nur Spec, Aussie dp, Blitz DSBC, Cone filter.
Phil-GT4RC
Postby CodingParadox » Sat Mar 03, 2007 10:09 pm
18-19psi on a stock unopened JDM motor, with a street brawler. Mods are on the page in my sig. Prolly 4k so far on this setup, no hint of problems.
CodingParadox
Postby theUNYTEDone » Sun Mar 04, 2007 12:24 pm
was it you that had the transmission problem, david? something that didnt line up unless you loosened it? :shrug:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby Wicked Toys » Sun Mar 04, 2007 8:24 pm
1991, Alltrac, 114k on a 2nd Gen 3SGTE
12 with spikes to 15 PSI
Been this way for 10k miles
Walbro 255 fuel pump, Blitz SUS Filter, Catless Exhaust, TMIC Fan, Stage 1 CT26 Turbo, Blitz BOV, ECU Re-Flash, Oil Catch Can, n FPR. Without checkin my complete list.
No problems since ownership in 04
Love the car and plan on slight more mods this year.
Wicked Toys
Re: How many PSI do you run on your stock motor???
Postby 1BADGT4 » Sat Mar 10, 2007 12:32 am
T-Trac wrote:I'd like to see what pressures people have been running on their stock motors.
Hey, you might want to ask what "octane" was being used.
UT2 (SCW) Chan - Oakland, CA
04 Duc Monster DS
400BHP @ 20#, low 12s
1BADGT4
Postby NoMan » Fri Nov 29, 2013 2:02 am
1992, ST185CS, 143000km.
~13psi.
~1000km
Electronic boost controller, Insulated W2A IC and airbox with K&N kone filter, atmospheric BOV.
No failures as of yet :D
Runs great and pulls hard but very grumpy on cold mornings, like its owner :lol:
NoMan
Postby warracer » Fri Nov 29, 2013 3:01 am
ST185H
160K mile
TD04L @ 18psi
3000miles, daily driven , no problem whatsoever
3inch turbo-back
front mount I/C
everything else is stock
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby underscore » Fri Nov 29, 2013 3:18 am
ST185RC, ~180k km, 3" DP, stock RC CT26 at 17psi.
