Some One Help Please Im lost need Info on turbo
Postby Kepster08 » Mon Oct 25, 2004 3:31 am
I have been searching for 3 days trying to figure out if toyota ever made a turbo for the 2.2L transverse engine in the 2wd Celica's. If not I Could use some advice on locating an aftermarket turbo. Please help. :cry: Thanks in advance.
Kepster08
Postby Smaay » Mon Oct 25, 2004 1:28 pm
I dont think toyota ever turboed the 5S-FE motor. but if you want to boost your celica i suggest you find a fabricator that can build you a kit. just bring him the part, ie, turbo, BOV, etc. if your in CA i recommend www.staffordfabrications.com I do some work for him and his quality is great.
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Postby gt_turbo » Mon Oct 25, 2004 5:56 pm
u should visit celica.net they have write ups on turboing a 5sfe
Lor Vang
91 Alltrac (sold)
93 GT Coupe (3sgte project)
92 ST Coupe (Beater)
gt_turbo
Postby BraveUlysses » Mon Oct 25, 2004 7:15 pm
Burien Toyota in Washington has a 5SFTE turbo kit you can buy.
BraveUlysses
Ty
Postby Kepster08 » Tue Oct 26, 2004 4:14 pm
Kick ass thx a bunch guys :)
Kepster08
Re: Ty
Postby Wraith » Thu Nov 11, 2004 7:01 pm
Kepster08 wrote:Kick ass thx a bunch guys :)
Stay away from stafford engineering... I have a few friends with some bad words about Stafford and their engineering work ....
Try going to check up on a s/c kit by rippmods or you can use a stock 3s-gte manifold from either celica or mr2 and it bolts right in ... And then you can use the ct26... But I suggest upgrading you fuel system first...
Wraith
Postby Shaggz00 » Thu Nov 11, 2004 9:40 pm
-Avi-
Shaggz00
Postby alltracman78 » Sat Nov 13, 2004 3:43 pm
You can make your own kit with parts from the 3S-GTE. The manifold bolts to the 5S head, the oil pan bolts on. You will also need the map sensor, as well as some other stuff [I've never done this..}.
Also, the 3S head will bolt on to the 5S block.
I also suggest getting a 3S water pump to deal with the extra heat.
FYI, the 5s is the same engine family as the 3S, so almost all parts will bolt on.
