ST205 motor in ST185
Postby 91redst185 » Mon Oct 25, 2004 11:02 pm
how hard is the swap? does it bolt right in or is there custom work to be done? is it worth it or just do the JDM 185 motor? planning on doing a swap this winter.
91redst185
Postby CMS-GT4 » Mon Oct 25, 2004 11:10 pm
Why?
Is something wrong with your engine?
Postby AWDios » Tue Oct 26, 2004 2:44 pm
You're going to get mixed reviews, but if you need to replace the stock motor, yes it drops right in, just make sure you can get an ECU and harness and hopefully the WTA I/C.
I did the swap, and I love it. I think it's a good way to go if you want to have a little more power to start with and you're more interested in building up your handling. But if you want all out power, you could probably build a very strong 185 motor for the same price.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby 91redst185 » Wed Oct 27, 2004 12:37 am
im pulling my motor to do a slow build up and i want to have one in there so i can still drive it. i think the 185 motor would be a cheaper swap, wouldn't it?
91redst185
Postby Rick89GTS » Wed Oct 27, 2004 3:07 am
91redst185 wrote:....i think the 185 motor would be a cheaper swap, wouldn't it?
Yep. 205 motors are harder to come by and higher priced.
Rick89GTS
Postby AWDios » Wed Oct 27, 2004 5:33 pm
but you're looking at 260hp stock compared to 200. Just depends on what's important to you.
www.pstoc.org
AWDios
