Stock ECU on 264 cams?????
Postby TraviST185 » Tue Oct 26, 2004 3:39 am
I know that to get the full potential of these cams you need EMS, degreed, dyno tune, big turbo....etc.
I just want to know how a fairly stock motor/turbo/ecu would react to these cams set to 0. Has anyone done this? What should one expect with this setup?
Travis Hanson
Postby » Tue Oct 26, 2004 4:21 am
I knew 2 people that had them on a stock setup. The first noted a increase in top end power on a CT26, and noted no negatives.
The other, had tuned his car to the edge on 440s, using an SAFC. He was making close to 300rwhp on a MR2. When he put the cams in, the motor blew. If you put the cams in, you'd have to erase any previous tuning and start from scratch.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
Site Admin
