Intercooling piping...
Postby -==L=a=N=c=E==- » Wed Oct 27, 2004 5:44 am
What are peoples thoughts when it comes to this piping size?
My power aims is atleast 200awkw by the time im finsihed, with room to expand if i so wish. I know the stock topmount is capable of holding this power, but i would much rather a FMIC solution, or a WTA intercooler if i can find one.
-==L=a=N=c=E==-
Postby Fat Trac » Wed Oct 27, 2004 7:26 am
go fmic. and check out this thread... water is almost as expensive and hard to find.
http://www.alltrac.net/phpBB2/viewtopic.php?t=1745
Fat Trac
Postby -==L=a=N=c=E==- » Wed Oct 27, 2004 7:55 am
Thanks for the link, but that didn't help me on pipe sizing. Also i won't be buying the kit, as i live in Australia, by the time i got it here, it would be hell of alot cheaper to get it done locally.
-==L=a=N=c=E==-
Postby busdriver » Wed Oct 27, 2004 3:03 pm
The pipe size you need would depend on whether you were going to upgrade your turbo or what psi you would be running. I think the most common choices would be either 2.25" or 2.5". If you run too big you are just going to see a lot of lag. I think I would go the 2.5".
Jake
90 st185
needs tlc
busdriver
Postby facapino » Thu Oct 28, 2004 12:59 am
i'm using 2.25" here is a pic on how it ran in my st191, not a celica but a corona/carinaE..hth
facapino
Postby -==L=a=N=c=E==- » Thu Oct 28, 2004 11:15 am
facapino: thats a decent setup you got there.
I think 2.25" is a good compromise on all counts. Thanks guys.
Now to decide on a turbo.
-==L=a=N=c=E==-
