st185 hks super sqv bov
Postby 903SGTE » Fri Oct 29, 2004 10:15 pm
i just got my hks sqv today and not sure how to install it.it came with the fitting on it to recirculate it back into the intake.do i need to do this or can i run it open??will the engine stall out if its left open?how is everyone else running there bov?? :doh:
903SGTE
Postby AWDios » Fri Oct 29, 2004 10:27 pm
Mine is open and fine.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby 935motorsports » Fri Oct 29, 2004 10:33 pm
You can leave the recirculate fitting on, but not route it in. I think it sounds better that way, personally.
Set the valve to full tight on the screw and you shouldn't have any stalling problems.
If you experience a stumble now and then, set your idle higher to compensate.
935motorsports
Postby T-spoon » Fri Oct 29, 2004 11:33 pm
If you already have the fitting, no reason not to use it. Recirculating is better when still using the AFM. If you vent to atmosphere, you will run richer and have a much less stable AFR, even if you don't run into stalling problems (mine did occasionally stall with sudden load-idle transitions when open to atmoshpere)
T-spoon
Postby 935motorsports » Sat Oct 30, 2004 12:00 am
I forgot to mention, if you go to a straight intake pipe, then yes use it. The car "will" drive better.
If you have a stock rubber intake pipe then re-circulation is a bit more difficult and you may as well stay VTA.
On my ST185, I had no adverse effects from VTA on the SSQV other then backfires (when set full tight).
935motorsports
Postby 903SGTE » Sat Oct 30, 2004 6:29 pm
i think it would also be more complicated to recirc. it.i also assume i need to cut that samco hose to fit?
903SGTE
Postby toayoztan » Sat Oct 30, 2004 7:11 pm
Yeah, you'll have to trim the length of the T-hose to fit between the turbo and IC. Just take your time and shave off a bit at a time til it fits. Remember to trim from BOTH sides to get it even on both sides of the T.
For the Recirculation on stock intake...is it a good idea or a "no no" to just tap the bov recirculation hose into one of the hoses (PCV or that other hose) on the stock intake?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby 903SGTE » Tue Nov 02, 2004 9:01 pm
so where should i reroute it back to?the pcv hose from the intake??
903SGTE
Postby alltrac4life » Tue Nov 02, 2004 9:09 pm
just don't mess with the intake. you dont need to recirculate the air.
AEM EMS,JE PISTONS,4 ANGLE VALVE JOB,PORTED HEAD,PORTED MANI.,EXAUST OF TURBO,57TRIM CT26,HKS 264 CAMS,SPRINGS,RETAINERS,3IN. EXAUST,CUSTOM INTAKE,MSD IGN.,SX FUEL REG. WOLFKATZ FUEL RAIL,550 INJ.,ACT 6-PUCK CLUTCH,HKS HG,FIDANZA FLYWHEEL
alltrac4life
Postby T-spoon » Wed Nov 03, 2004 5:22 am
Ok, you don't HAVE to recirculate. If you choose to, take a look at Chris Dittrick's setup, very tidy :)
T-spoon
Postby 903SGTE » Wed Nov 03, 2004 10:19 am
do you have a link to his setup.i really dont want to recirc. it but im worried about running problems.
903SGTE
Postby alltrac4life » Wed Nov 03, 2004 4:30 pm
i suggest you try driving around and when it runs perfectly fine, you will know what to do.
alltrac4life
Postby scott » Thu Nov 04, 2004 10:45 pm
iv got a hks valve on mine and i found it made the car very jittery and allway stalled even after loads of adjusting and even tryed restricors on the vac line so now i have it recirculated but i really miss the sweet noise it made when it dumped it scared all the racers round my area
1990 import
st185
scott
Postby alltrac4life » Thu Nov 04, 2004 11:09 pm
It shouldnt do that if it is installed and adjusted properly.
alltrac4life
Postby scott » Thu Nov 04, 2004 11:15 pm
i was told that it will stall coz of the loss of air that the afm has metered
it has also made it kick out a flame every now an then if im driving hard coz off it running rich
1990 import
st185
scott
