Intake installed, bad idle!
Postby PhilipK » Mon Nov 01, 2004 1:57 am
Hi, I just installed an straight intake with the two nipples on it, with a catch can and now the car does not idle right; only idles for 2 secs then shuts off. I ran the hoses correctly, there is two outlets coming from the engine, the first one I ran straight to the intake and the one below that, coming from the crank case, I ran to the Catch can then to the other nipple on the intake. Is this correct. Anything else I can check.
Thank you
PhilipK
Postby ChrisD » Mon Nov 01, 2004 2:13 am
Probably something simple. Check your clamps. Is your afm hooked up right?
1988 ST165
1994 ST205 WRC
ChrisD
Postby MrWOT » Mon Nov 01, 2004 2:14 am
You've got a vac hose disconnected. That's what happens when engine has vac under 10inHg. It'll start, idle for about 2 seconds then die. When I installed my CAI i forgot to reatatch the oil breather line and that did it for me.
MrWOT
Postby PhilipK » Mon Nov 01, 2004 2:16 am
Well the hoses I had to push on so they are tight and I clamped them down really good. All I did was extend the AFM wires and mounted the AFM on its side and it just plugs in right!
PhilipK
Postby -==L=a=N=c=E==- » Mon Nov 01, 2004 2:24 am
Check all your AFM connections, you might have a loose wire. Also make sure its plugged in (i forgot that small detail...)
-==L=a=N=c=E==-
Postby Gary » Mon Nov 01, 2004 2:50 am
Please tell me you didn't remove those 2 screws on the AFM connector.
93 ST185
Gary
Postby PhilipK » Mon Nov 01, 2004 2:55 am
I did, I misread somewhere about that, but I did get a AFM off a Mazda that looks just the same everything. So I guess that is my problem, I was hoping it would not be that. So what AFMs can I get that will work for sure.
PhilipK
Postby -==L=a=N=c=E==- » Mon Nov 01, 2004 2:55 am
Gary wrote:Please tell me you didn't remove those 2 screws on the AFM connector.
seconded, it seems to be a common error.
-==L=a=N=c=E==-
Postby Gary » Mon Nov 01, 2004 3:00 am
93 ST185
Gary
Postby PhilipK » Mon Nov 01, 2004 3:06 am
Ok, but what AFM with work with it, will I just have to get one off another 1991 ST185, and I take it that will be tuff to come by.
PhilipK
Postby -==L=a=N=c=E==- » Mon Nov 01, 2004 3:12 am
ilikemycelica wrote:Ok, but what AFM with work with it, will I just have to get one off another 1991 ST185, and I take it that will be tuff to come by.
You can have a go at fixing it yourself, but your going to have to beg,borrow,steal one from somewhere.
MrT (Toyota) will rape you a nice amount of money for the AFM, so start looking. Maybe a good time to go aftermarket computer :D
-==L=a=N=c=E==-
Postby PhilipK » Mon Nov 01, 2004 3:15 am
Well, what does the aftermarket comp entail... Alot of work I guess and money.
PhilipK
Postby furpo » Mon Nov 01, 2004 3:28 am
yes a lot of money, a lot of time, and a lot of searching. unless you really need to stick with the standard ecu. good luck trying to find an afm. i have one over here in new zealand if you can not find one closer to home.
have a final look around and cheak to see all the plug in the engine bay are pluged in. if the resistor pack with the square plug is unpluged a similar thing happens.
roger
furpo
Postby -==L=a=N=c=E==- » Mon Nov 01, 2004 3:40 am
i too also ahve an spare AFM here, but im in Australia, which is even further away then the kiwi.
Atleast in america the MR2/Alltrac alliance is much stronger then what can be found in australia. So you'll have a much better time finding one, just start hunting.
-==L=a=N=c=E==-
Postby PhilipK » Mon Nov 01, 2004 4:59 am
Well, how hard is it to ship to the US? and how much are you asking?
PhilipK
