compressor upgrade
compressor upgrade
Postby crazyGT4 » Mon Nov 01, 2004 5:45 am
hey all,
first ever post to the forum!! was after some advice. I know a lot of people fit T04E compressor wheels to their CT26 for higher boost with the same spool up time etc. I have just been offered a good deal on a T04E wheel and compressor housing. Is it possible to fit the housing to a CT 26 to save machining the existing housing? if so, does fitting the new wheel and housing need to be fitted and balanced by a pro, or is it easier enough to do myself?
crazyGT4
Postby OlyST185 » Mon Nov 01, 2004 5:56 pm
you must get it balanced by a pro at something like 100 000rpm
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby smc252 » Tue Nov 16, 2004 1:47 am
The CT-26's mid-section (where the oil goes) has a different bolt pattern then a T4 or T3 so the housing will need to be modded (good luck.) Quite honestly, I would just upgrade to a full t3 or t4 or a hybrid (I did.) More power, quicker spool and a better powerband. I don't see why so many people try to squeeze power out of the CT26? (Which is a joke over 1 bar of boost.)
-Steve
1988 All-Trac
(Rotting away, fiending for a tranny.)
1986 Celica GTS
(GT3071R forced 3s-gte + autronic smc)
smc252
Postby MrWOT » Tue Nov 16, 2004 1:55 am
smc252 wrote:The CT-26's mid-section (where the oil goes) has a different bolt pattern then a T4 or T3 so the housing will need to be modded (good luck.) Quite honestly, I would just upgrade to a full t3 or t4 or a hybrid (I did.) More power, quicker spool and a better powerband. I don't see why so many people try to squeeze power out of the CT26? (Which is a joke over 1 bar of boost.)
-Steve
Tell that to Griffin :smokes: He's pushing about 30psi with a ct26 as I recall
MrWOT
Postby alltrac4life » Tue Nov 16, 2004 3:35 am
Yeah, mine will be doing that too. If you know what upgrade to get, and what to port on the exhaust side then it will make a shit ton of power.
AEM EMS,JE PISTONS,4 ANGLE VALVE JOB,PORTED HEAD,PORTED MANI.,EXAUST OF TURBO,57TRIM CT26,HKS 264 CAMS,SPRINGS,RETAINERS,3IN. EXAUST,CUSTOM INTAKE,MSD IGN.,SX FUEL REG. WOLFKATZ FUEL RAIL,550 INJ.,ACT 6-PUCK CLUTCH,HKS HG,FIDANZA FLYWHEEL
alltrac4life
Postby Fat Trac » Tue Nov 16, 2004 5:11 am
the ct27 sounds very interesting...
Fat Trac
Postby BoostedBlueToyotas » Tue Nov 16, 2004 5:31 am
Another vote for the CT27, anything over 17-18 psi on the stock
CT26 and you have a hair dryer :shoots:
Tim Plessing
Columbia, MD
BoostedBlueToyotas
