How to 400 awhp
Postby Hotrodhendrix » Tue Aug 07, 2007 2:45 pm
I know this doesnt go along with the thread but i got another question. When I got the car it had a bad stumbling problem so I switched out the afm's and bam problem solved. My intake lines have a fairly large amount of oil in them. What could this be?? Bad turbo... :cry:
Postby Simba » Tue Aug 07, 2007 3:04 pm
Hotrodhendrix wrote:I know this doesnt go along with the thread but i got another question. When I got the car it had a bad stumbling problem so I switched out the afm's and bam problem solved. My intake lines have a fairly large amount of oil in them. What could this be?? Bad turbo... :cry:
Probably either the PCV (unless you have a catch can) or the turbo compressor oil seal.
If the turbo is a rebuild, I'd put money on it being the seal.
Lots of fast, loud things.
Simba
Postby Hotrodhendrix » Tue Aug 07, 2007 3:12 pm
I dont think it has been rebuilt yet. It will probably need it tho. I will check that out when i rip her heart out this weekend. Its time for the engine swap.
(No catch can as of right now)
Postby darthripley » Tue Aug 07, 2007 5:15 pm
its normal to have some oil without a catch can, but if there's a lot then the seals on the turbo are toast & consider it rebuild time.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby Hotrodhendrix » Tue Aug 07, 2007 5:25 pm
Thats not a big deal. I figured this into my rebuild. Plan for the worst hope for the best. Anyways anyone know of a good rebuild kit for the td06 20g?
Postby toayoztan » Tue Aug 07, 2007 7:52 pm
Hotrodhendrix wrote:Thats not a big deal. I figured this into my rebuild. Plan for the worst hope for the best. Anyways anyone know of a good rebuild kit for the td06 20g?
A good rebuild kit would be to get a different turbo :D Jk, jk!
I don't recommend you buy a rebuild kit and do it yourself. Call around and have a reputable shop rebuild the turbo for you.
Also, you should check to see if you have oil in your AFM. Depending on severity, if you have oil seals going out then you'll probably have oil residue in the AFM.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby Hotrodhendrix » Tue Aug 07, 2007 7:54 pm
I will check tonight. I have only started it a few times sence I replaced the afm. Thats what clogged the last one so it must be that. Does ats rebuild turbos?? 8)
THere only 45 min away!
Postby Simba » Tue Aug 07, 2007 11:35 pm
Hotrodhendrix wrote:Does ats rebuild turbos?? 8)
No, they farm them out to random shops with questionable quality control.
Simba
Postby darthripley » Wed Aug 08, 2007 12:22 am
i'd recommend Majestic Turbo in Waco to do the rebuild.
they did a great job with ours & did everything just as we wanted it.
Female Moderator
darthripley
All Trac Goddess
Postby Hotrodhendrix » Wed Aug 08, 2007 12:33 pm
darthripley wrote:i'd recommend Majestic Turbo in Waco to do the rebuild.
I will take a look into them. Thanks.
Postby Hotrodhendrix » Thu Oct 25, 2007 2:11 pm
Ok I picked up an intercooler yesterday off of craigslist. Its in really good shape and looks like it will fit perfect behind my CS front bumper. Anyways... It has 3" inlets and outlets (outer).. Is this a good or bad thing for my power goals? :shrug:
Also the owner didnt know what brand it was either. He picked it up off of craigslist also but was to big for his honduuuu. :lol:
Is there a usual place they place the brand name?? I looked around the outside and couldnt find anything.
Postby Hotrodhendrix » Thu Oct 25, 2007 2:14 pm
Heres the link
http://dallas.craigslist.org/pts/432972562.html
LOL I talked him down from his firm price.. :evil:
Postby tjdouble07 » Thu Oct 25, 2007 3:34 pm
theUNYTEDone wrote:is there a thread confirming that the trac dyno's just about similarly in fwd mode? i caught no wind of that whatsoever...very interesting.
CodingParadox wrote:Kris Osheim was dynoing some guy's 500awhp GT35 stroker and found only a very small difference between 4WD and 2WD mode. I'm not sure if it's documented anywhere. I'll try to remember to ask him about it next time I talk to him.
Man, I need to read the boards more often... :doh:
Yeh, Kris and I only saw a 2-3% difference in measured hp between FW mode and AWD mode with back to back dyno runs.
I went a little deeper into discussion on this topic after I came back to Utah, did a few more mods on the car, and got it redynoed here in Utah.
Basically with STD correction, when I dyno'd in Oregon on 29 psi, I made 528 WHP. After some head porting and a tubular exhaust manifold, on the same boost levels I saw 534 WHP in FW mode. Here's my dyno day thread where I went into further discussion on the topic.
http://www.alltrac.net/phpBB2/viewtopic.php?t=23395
I'm sorry if this has already been discussed; I'm sometimes not quite up to speed on topic discussions, and haven't fully read this topic yet... :oops:
Trevor
1990 Celica GT-Four, runs 10's
tjdouble07
Postby alltracst185 » Thu Oct 25, 2007 3:36 pm
it lokks like the obx core, the bay area fm kit uses the same core.
alltracst185
Postby lumbercis » Thu Oct 25, 2007 3:54 pm
3" inlets and outlets are fine, yor biggest problem will be fitting 3" piping in the engine bay. I have 2.5" and it's pretty cramped, but people have done it.
You could run 2.5' piping, but then you won't see any flow benefit from having the big 3" in/outlets. I'd try to get 3" pipes in there somehow. Clocking the turbo down may help.
J.
lumbercis
