stock st185 engine mounts
Postby silverarrow » Mon Nov 08, 2004 6:00 am
Anyone have pictures of the front and rear engine mounts? If anyone does, please post them on here as I'd like to see how they look like. Kirkosaurus from the mr2 boards makes poly inserts for mk2's and I'd thought since both cars use the 2nd gen 3sgte then maybe they may share similarities of the engine mounts too.
89 240sx
07 Versa SL
silverarrow
Postby alltracman78 » Mon Nov 08, 2004 11:14 pm
Front and rear mounts are on the transmission.
But a MR2 trans will work in a fwd Celica, which has the same mounts as a Alltrac. :|
Postby silverarrow » Tue Nov 09, 2004 4:08 am
I think the driverside mount is the only transmission mount, not sure about the rear. I forget if it was on the engine or transfercase? Hmm...
Anyhow, that's what I was thinking but Kirk from the mr2 board sent one set of the inserts to one of his buddies with a 93 all trac and we will soon find out. :D
89 240sx
07 Versa SL
silverarrow
Postby gt_turbo » Tue Nov 09, 2004 4:59 pm
there 3 mounts on the alltrac tranny. front, side, and rear. and ppl who use mr2 trannys for swaps, have to switch to alltrac mounts so that it will line up with the alltrac crossmember.
Lor Vang
91 Alltrac (sold)
93 GT Coupe (3sgte project)
92 ST Coupe (Beater)
gt_turbo
Users browsing this forum: Bing [Bot] and 6 guests
