ST165 front mount intercooler???
Postby 89st165 » Tue Oct 30, 2007 10:32 pm
is it possible/beneficial to exchange the oem top mount to a front mount??? what is process intail? possible pic's would be great.. thanks still new to the brand and the car, learning more and more everyday thanks :D :D
1989 st165
Postby Letze » Tue Oct 30, 2007 10:38 pm
I dont believe there is enough space to do so...
Eric has an ST185 swap and I think he still uses a stock 165 WTA IC...
Postby MrWOT » Tue Oct 30, 2007 10:48 pm
Bigger WTA is the way to go
Postby WarTowels » Tue Oct 30, 2007 10:51 pm
Defiantly possible.
It will drop your charge temps considerably over the stock WTA IC. My understanding is this will allow you to run more boost if you want, or *should* increase HP on stock boost since the temps will be much better.
FMIC also LESS susceptible to heat soak because it's farther away from the engine temps and in the direct flow of incoming air.
Some guys with ST165 I'm sure can chime in with what setups they are running and what size IC's fit the stock bumper.
2003 S2000
1985 300TD
Gold GTfour God
Postby Gary ST165 » Tue Oct 30, 2007 11:07 pm
ST165 turbo 4WD
Gary ST165
Postby built2run » Wed Oct 31, 2007 2:48 pm
or u can just relocate ur battery and place a real nice 2.5"/2.5" WTA core and use a larger heat exchanger like a radiator off a late 90's vw with a 10-12" electric fan and the constant run mod on the ic...... do some research a well done WTA is best for cooling the charge and it cools from the get-go but ATA is lighter, less complicated, and looks better to most.
ST165, black: parted and gone
ST165, white: sold to friend
Postby MrDB » Thu Nov 01, 2007 8:38 pm
Heres a possibility/idea,
Use an escort cosworth frontmount, has a charge cooler built into air to air cooler. Run current charge cooler water lines to it and have best of both. Intercooler is small also and supports approx 400bhp. Im running a sierra cosworth a2a one in my 185 now difference on mine was awesome.
Postby gearhead313 » Sun Nov 04, 2007 12:09 pm
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
Postby Red Rabbit » Wed Nov 07, 2007 5:48 pm
Klas is running a FMIC in his st165 at the moment, just hit up his thread in the my project alltrac section of the forum.
1984 Mustang Beater- Blew up
1988 ST165- Project
1992 ST184- Totalled
1993 S13 Turbo- Sold
1995 Impreza Outback Sport- Other daily
1997 S14 Kouki- Might sell might project
1991 Turbo MR2- New daily
Red Rabbit
Postby stevo27 » Fri Nov 09, 2007 3:20 am
theres TONS of room im running a 32x12x4" fmic and i coulda went with a 34x18x4 :twisted:
No longer a member of the AWD club
just a powerglide and rwd for me
"breaking records and breaking parts go hand in hand"
Postby toayoztan » Fri Nov 09, 2007 3:34 am
By room, i think he may have meant airflow to the FMIC.
In any case, War Towels, i think you meant the fmic is less susceptible to heat soak :wink:
I'd say go for an FMIC if you can, however, i don't think there's really many bumpers out there (except maybe what Mafix used) to open enough clearance for good air flow to the FMIC.
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1993 Alltrac -
1977 Celica GT Liftback
2015 Grom
1977 GL1000
Postby 86turboswap » Fri Nov 09, 2007 5:01 am
I am using a ST185 RC vent in my ST165 with a ST185RC W:A Intercooler,
gonna use a large heat exchanger & build a duct hooked into the front grill to directly route the air through the Heat exchanger. Might use a small fan but I don't think it will be necessary in combonation with dual stage water injection.
Postby WarTowels » Fri Nov 09, 2007 4:36 pm
Yes, I meant FMIC's are less susceptible to heat soak.
Edited my above post.
2003 S2000
1985 300TD
Gold GTfour God
Postby 88Allheeze » Fri Nov 09, 2007 9:44 pm
i got some pics on my putfile
Postby Azonic » Wed Nov 14, 2007 8:00 pm
Would the FMIC increase the turbo lag, and increase the pressure drop from the TM WTA IC?
1988 ST165
1990 F350
2002 VW Jetta TDI
2002 BMW K1200RS - Dakar Yellow!
and how many MR2's did I have? I forget..
