FMIC blocking radiator?
Postby CelicaGT4 » Sun Nov 14, 2004 11:47 pm
I bought my FMIC about a month ago and am installing it this week. I've just been wondering if it's going to completely block air to my radiator and cause overheating. It is 28x12x3 and completely blocks my radiator horizontally and leaves about 4 in. on top of the radiator still open to air flow.
Www.gemstatepestsolutions.com
CelicaGT4
Postby ChrisD » Sun Nov 14, 2004 11:55 pm
Air still flows through the IC to the radiator, keep in mind. So it won't be blocked from the air. However, the air will be warmer. That said, yes it does remove some degree of efficiency from your radiator's effectiveness, but I've never seen a case where it actually caused any sort of problems on a celica.
Cars often have multiple radiators lined up, A/C, WTA IC heat exchanger, tranny cooler, radiator, etc.
1988 ST165
1994 ST205 WRC
ChrisD
Postby CelicaGT4 » Mon Nov 15, 2004 12:03 am
True, the nice thing is....I took my air conditioning out so I don't have the condensor up in front. just Front mount and radiator.
CelicaGT4
Postby Zeus » Mon Nov 15, 2004 12:10 am
yeah nothing to worry about really
big turbo deisel trucks have like 8 heat exchangers in the front
ac ic rad oil cooler tranny cooler ect
Blake Brown
Zeus
Postby BraveUlysses » Mon Nov 15, 2004 1:32 am
If your FMIC core was REALLY big and covered the whole radiator area, then it would be a cause for concern, but you should be just fine. Volvos have had FMIC for over 20 years and they usually didn't ever have problems except from hard track use.
BraveUlysses
