randomly getting code 34 (turbo pressure signal)
Postby gpmarzan » Tue Nov 16, 2004 8:39 pm
i just replaced my turbo so that cant be it. im running a manual boost controller so i plugged the vac line going to the turbo pressure sensor as instructed by the info on this site. how else could this code be popped up? up next in the BGB is the ecu but how often is the ecu cause of this code? right now i have a slipping clutch. would that cause the code to show somehow?
gpmarzan
Postby alltracman78 » Wed Nov 17, 2004 12:15 am
Sensor itself could be bad :shrug: [don't have bgb in front of me..].
clutch shouldn't cause that.
Are you sure you plugged the right line?
Postby gpmarzan » Wed Nov 17, 2004 1:00 am
alltracman78 wrote:Sensor itself could be bad :shrug: [don't have bgb in front of me..].
i plugged both the wastegate side and the vsv side and left the connector connected to the sensor.
question though, if its already plugged, why is it showing the code? the code flashes right when the car feels like its hitting boost/fuel cut or something. it happened today when i was showing my friend how bad my clutch was slipping. it didnt happen when i showed him, but right after when i started rolling from a stop light. i think i was half throttle in 1st and the car suddenly just lost total power and was bogging, then i saw the engine light flashed and code 34 is what it showed
gpmarzan
