I was just wondering if this turbo would be much better than any CT26 upgrade including the CT27 upgrade from ATS Racing.
I would think that this would be better since it has a better compressor and turbine wheel. Think this would easily flow 300 hp or should I stick with the CT26 or plan for the CT27 turbine upgrade for 450.
The T3 is pretty cheap, its a 60 trim with a .48 AR exhaust so it should have some good spool up and pull pretty good. I can probably get an adapter, a T3, and a downpipe made for like around 700-800 bucks, probably even cheaper. The turbo will have an internal wastegate but I am trying to look stock.
Any other ideas for internal wastegated turbos that aren't a total give away from a turbo upgrade?
