Moderator
The connectors are the same on both 185/205. You will need to check the pin-outs since some of the used/non-used pins are different.
RedCelicaTRD":25kjmir8 said:The connectors are the same on both 185/205. You will need to check the pin-outs since some of the used/non-used pins are different.
allblackalltrac":1zzem4t2 said:I'll help you guys out by clearing up some confusion
That motor IS a rev3 3SGTE - you guys already new that.
The MAP sensor is a 2 bar MAP 90-93' 3SGTE.
The ECU is a 92' 3SGTE AllTrac ecu - 93's end with 2B290
Now the one that everyone wants to know, that harness is a RC/CS harness, that 5 pin connector that no ones can seem to identify is for the RC/CS AFM, its distinctive because it uses a round connector instead of the square connector on all other revisions of the 3SGTE that use an AFM.
I knew I was right about that connector
This is the best thing that you can do to make that engine run correctly in a 165. Use the ST165 engine harness, if you dont have one - find one, sell the RC/CS engine harness to offset the costs of a ST165 engine harness if you dont have one. Sell the 2 BAR MAP and rev2 3SGTE ecu and obtain the rev3 3SGTE ecu, air temp sensor and 3 BAR MAP.
Now custom make a ST165>ST205 ecu conversion adapter, hint rev3 and rev2 male recepticals are the same number of pins. Dont cut them off the ST185 harness just becasue you have them, it will depreciate the value of that harness. Buy the connectors online brand new theres a thread on here titled 165>185 ecu conversion harness, you'll find the website and part numbers you'll need to order from. The ST165 engine harness will still need some of the connectors replaced for the rev3 sensors but its not hard. If your in need of a ST165 engine harness and conversion adapter I can supply you with both.
CMS-GT4":31zw1qud said:Evo_VIIIMR":31zw1qud said:i ohmed the wires and they go to the following THA PIM THAM and E2x2.
If that is the case, I have a feeling there is a major cable splitter that you are missing.
There must be a connector for that plug that has a split for the THA that goes under the throttle body, the THAM that goes to the airbox etc.. I might have THA and THAM backwards.
I used the 185 harness and just had to move a few pins around at the ecu and wire in the sensors and I was done.
