Oil lines for a T3 turbo
scemracing
Besides the WRX top mount I also picked up a freshly rebuilt T3 it isnt huge but I think it will work fine for a replacement turbo. Where on the block do I get the oil feed do I plug up the stock one and get oil from somewhere else or is the stock one taped so I could use earls fittings and a S.S. line to feed my turbo. I know with the return I will just make a new hose to fit the stock oil pan drain.
Thanks
Jason
scemracing
I know people on here have installed a t3/t4 on there All-Trac can someone please help me out with where to feed the turbo with oil from is there some where to pull out a plug on the head, block can someone please help me.
pog0
Not too sure why you have a WRX TMIC but yeah.
I believe on the block there should be a HUGE 27mm banjo bolt... and thats where the oil feed comes from.
Yea definately pick up that piece if you can. I fabricated my own fittings to the stock feeds when I installed my T3/T4. It was a royal PITA. I am going to get that banjo bolt as soon as I have the time to install some things.
