Ok
On my third turbo now. Bought the car with bad turbo seals(Turbo 1). Smoked like hell.
Buy a used turbo(Turbo 2). Put in on. Make 7 pounds of boost once to a loud noise. Pull over everthying looks fine. Won't make boost anymore. Examine it next day and the nut tightening the compressor blades to the shaft isn't tight. Seems as though the shaft is spinning inside compressor blades. Tighten the nut. Still make no more boost. When i check if the nut has loosened again, it hasn't its TIGHT.
Buy 2nd used turbo(Turbo 3). Begin to remove first used replacement. Notice that where the wastegate bolts up to a bracket on the right side of the turbo(also where some coolant lines bolt up to a bracket) IS NOT bolted up. Think, holy carp this musta been why i wasnt making any boost. My wastegate was stuck open. Decide to replace with Turbo 3 anyway b/c its in best condition with hardly any shaft play at all. Replace it and get everythign hooked(besides downpipe to the under car exhuast) up and go to drive the car. Don't make any boost! Boost gauge read 1 pouond a couple of times compared to turbo 2 that never read above 0. It almost sounded like I could hear some spoolng but with this exhaust disconnected the car was so damn loud i'm not sure.
I'm at a loss and am getting turned off on working on this car. Its been my dream car for so long but I've had no luck so far. Help me regain my love!
Questions and ideas I've come up with.
When I bought the car, looking at the wastegate it has TWO nipples on it. One of them has a vaccum hose going off of it towards the firewall. The other one is plugged. What is the second nipple for? (This was like this on while Turbo 1 was on the car and I DID make boost)
Also to determine if wastegate is faulty: is it a good idea to pull vaccum hose that goes to wastegate and do a 3rd gear pull higher up in the rpms to see if i start to make a slight amout of boost up high in the RPM's. Reason I say 3rd gear is so that I can somewhat controll the boost with the throttel and will be less likely to overboost.
All your help is greatly appreciated.
Mark
Mark
