AllTrac.net Dyno Top Ten
Postby RedCelicaTRD » Sat Dec 27, 2008 10:47 pm
We will be making a list of the top ten HP cars on AllTrac.net. If you think you have what it takes to get on the list, please reply with the following information:
Dyno Sheet
Peak HP: (452@6850rpm)
Peak Torque: (396@4300rpm)
Type of Dyno: (2WD or AWD)
Brand of Dyno: (i.e. Mustang, Powerflow, DynoPak, DynoJet, etc.)
Engine Displacement: (Stock, .020 over, 5s Stroker, JUN stroker, etc.)
Engine Compression: (Stock, 9.0:1, 8.5:1, etc.)
Camshafts: (stock, JUN 264 high lift, HKS 272, etc.)
Turbo: (stock, GT35, T3/T4 50trim, BW S236, etc.)
Turbo Pressure: (25psi, 1bar, etc)
Fuel: (550cc w/ Supra pump, 1600cc w/ 3 walbros, etc.)
Fuel Type: (91oct, E85, VP Import, etc)
Engine Managment: (AEM EMS, Power FC, SAFC, etc.)
Other Info: (DO NOT include your complete mod list here. Keep it short with important info i.e. 5s block, filled block, +1mm valves, etc.)
We will not be including FWD swapped cars, MR2's or other platforms with 3s based motors. All Tracs/GT-Fours ONLY!
AWD Dynos
Postby RedCelicaTRD » Sat Dec 27, 2008 10:48 pm
Top Ten AWD dyno numbers!
1. fhalperformance Peak HP: 400@7700rpm Peak Torque: 320@6200rpm
2. Mixer72 Peak HP: 395.7bhp Peak Torque: 370ft/lbs
3. st185pinjo Peak HP: 281 AWHP@6719rpm Peak Torque: 281
4 93cc Peak HP: 279.2@5500rpm Peak Torque: 292.6@4250rpm
5. TheNubkins Peak HP: 261.9@5900rpm Peak Torque: 243.6@5075rpm
6. MrDB Peak HP: 241.24 Peak Torque: 296.45
7. Turbo4WD Peak HP: 234.60 @ ~4400rpm Peak Torque: 296.45 @ ~4000rpm
8. CSAlltrac Peak HP:213@5602 Peak Torque:251@3932
9. Tissmo Peak HP: 212.56 @ ~5400rpm Peak Torque: 230.87 @ ~3600rpm
10. tubasteve Peak HP: 187.77 @ ~5600rpm
Last edited by RedCelicaTRD on Sun Nov 15, 2009 10:36 pm, edited 10 times in total.
Top Ten FWD dyno numbers!
1. timmey Peak HP: 187.1 whp @ 5850 rpm Peak Torque: 195.8 ft lb @ 4200 rpm
2.
3.
4.
5.
6.
7.
8.
9.
10.
Last edited by RedCelicaTRD on Sun Nov 15, 2009 10:34 pm, edited 3 times in total.
Re: AllTrac.net Dyno Top Ten
Postby tissimo » Thu Jan 01, 2009 4:31 pm
I'll post my stock one for kinda of a dyno registry as well
Dyno Sheet
Type of Dyno: AWD
Brand of Dyno: Dynojet
Engine Displacement: Stock
Engine Compression: Stock
Camshafts: Stock
Turbo: Stock
Turbo Pressure: 14 psi falling to 12 psi
Fuel: Stock fuel (injectors, pump, regulator, rail)
Fuel Type: 93 Octane
Engine Managment: AEM EMS
Other Info: 105*f in the dyno room (damn fl summers)
98 Supra Turbo
92 Supra Turbo
90 Celica Alltrac
tissimo
Postby turbo4wd » Fri Jan 02, 2009 6:04 pm
tissimo wrote:I'll post my stock one for kinda of a dyno registry as well
If that's stock, with only increased boost & AEM, then that's pretty damn impressive, especially on a 105* FL day.
Here's mine from a few years back:
Dyno Sheet
Type of Dyno: AWD
Camshafts: Stock
Turbo: Stock
Turbo Pressure: 11psi
Fuel Type: 91 Octane
Engine Managment: Stock
Other Info: 3" turbo-back w/ hi-flow cat, GT-R core FMIC, MR2 TB neck, AFM mod
Dan
Undercover Moderator
turbo4wd
Postby ChrisD » Mon Jan 05, 2009 4:02 pm
Everyone is also more than welcome to use the one I built to replace my gtfour.ca registry:
http://myautosphere.com/home/modules/al ... view&cid=4
I understand the desire to have an alltrac specific one though, so having this one here is valuable too. :)
1988 ST165
1994 ST205 WRC
ChrisD
Postby smog7 » Mon Jan 05, 2009 7:05 pm
Dyno Sheet
http://www.turbo4wd.net/alltrac/dyno.jpg
Type of Dyno: AWD
Camshafts: Stock
Turbo: Stock
nice numbers using the stock turbo! pretty much exactly what I want to do with my car. what exactly does the AFM mod consist of?
-omar
rally tarmac 1990 st185
smog7
Postby ST185pinjo » Mon Jan 05, 2009 10:12 pm
Are these numbers AWHP, or engine HP?
ST185pinjo
Postby RedCelicaTRD » Mon Jan 05, 2009 10:15 pm
All numbers are at the wheels. For the two that have already posted it was on an AWD dyno so AWHP.
Postby tissimo » Tue Jan 06, 2009 3:06 am
I did have a 3" exhaust, stock intake w/ paper filter though (still had afm in as I was lazy and didn't take it out, even though was speed density)
I have a hard time beleiving your 29x ftlbs at 11 psi.
98 Supra Turbo
92 Supra Turbo
90 Celica Alltrac
tissimo
Postby MrDB » Tue Jan 06, 2009 12:21 pm
Peak HP: 241.24
Peak Torque: 296.45
Type of Dyno: AWD
Camshafts: Stock
Turbo: Turbotechnics S148 Hybrid
Turbo Pressure: 0.9bar
Fuel Type: 98 Octane
Other Info: 3" turbo-back , FMIC
Graph at fly.
MrDB
Postby ST185pinjo » Tue Jan 06, 2009 2:05 pm
Dyno Sheet
Peak HP: 183 AWHP@5380RPM, 235 engineHP @6280
Peak Torque: 307[NM](~226 lbf ft)@4931 measured at engine.
Type of Dyno: AWD
Brand of Dyno: Superflow
Camshafts: Stock
Turbo: Stock
Turbo Pressure: 0.7 bar ~11psi (usualy 15 psi, but on the dyno it wouldn't reach that)
Fuel: Stock
Fuel Type: 98Ron
Other Info: 3" turboback, K&N replacement panel.
This is my stock base dyno. Please keep in mind I have a CS version, so WtA.
ST185pinjo
Postby ST185pinjo » Tue Jan 06, 2009 2:13 pm
@turbo4wd.
There is something strange in your graph. You seem to lose HP and torque after 4000RPM.
If you look at other dyno's most of the peakHP is around 5500 rpm.
If I look at your A/F, that is very nice curve for even a tuned engine. A/F ~11.5 under boost. :shrug:
ST185pinjo
Postby turbo4wd » Wed Jan 07, 2009 5:02 am
ST185pinjo wrote:@turbo4wd.
Not really, my graph is similar to yours except the power came on about 1000rpm sooner. Your graph shows the same decline in torque while maintaining the same steady hp reading. The main reason for this is the stock turbo since it is a bottleneck. If you look at MrDB's graph he's running a different turbo but seems to be a similar setup to mine, and his curves are different as his hp output keeps going up and doesnt taper down until the very end.
As for the A/F, the AFM was opened and the wheel was moved, unfortunately I wasn't the one who did it, so I don't know how many clicks were put on it from stock - the guys at the shop were very concerned with how lean it was during the first 1000rpm of the pull.. this lean condition occurred on the 4 pulls we did. We ended up adjusting and closing down the AFM bypass screw to help richen it up.
As for it being set at 11psi, shortly after this I installed the AEM, and the MAP sensor verified the reading on my boost gauge.. I haven't messed with it since so :shrug:
This engine has since come out of the car and been rebuilt with forgies, but I haven't put it in yet.. I put in another stock JDM engine with a different fuel setup - but still running a stock turbo and the same AFM. Although driving around recently - the car actually feels slower than it did before so I dunno.. I can't say for sure until I get a chance to dyno it again. I'm hoping to do it again in the next few months..
But before that, I've got a few more things to buy first :wink:
Dan
turbo4wd
Postby turbo4wd » Wed Jan 07, 2009 5:08 am
smog7 wrote:nice numbers using the stock turbo! pretty much exactly what I want to do with my car. what exactly does the AFM mod consist of?
Thanks, here's a good article regarding the AFM mod - its talking about another Toyota engine, but the procedures / concepts are the same. You start with removing the black plastic cover on your AFM to access the gearing.. but as mentioned before here on this forum and in this article - proceed at your own risk.. It's best to do this with a wideband to monitor but even so..
http://www.well.com/user/mosk/AFM1.htm
Dan
turbo4wd
