AllTrac.net Dyno Top Ten
Postby Hic » Thu Nov 19, 2009 6:26 am
Matt
Hi Matt
I am very nicely surprised with your dyno graph.
Can you please tell me is this a wheel HP or flywheel estimation?
If this is flywheel, can you tell me the WHP?
Also, did you resleeved the block or you use thick block?
Thank you very much
Hrvoje
Hic
Postby Mafix » Thu Nov 19, 2009 2:04 pm
that should be BHP which is close to crank.
Postby fhalperformance » Tue Nov 24, 2009 3:49 am
thought i would throw up a dyno from my car. I unchecked one of the scalling options in this picture but the numbers are right.
Peak HP: 400whp@7700rpm approx
Peak Torque: 320wtq@6200rpm approx
Type of Dyno: AWD
Engine Displacement: 2.2
Engine Compression: 8.3:1
Camshafts: HKS 264
Turbo: GT35r
Turbo Pressure: prob around 15psi
Fuel: 1200cc
Fuel Type: 93oct
Engine Managment: Autronic SM4
Other Info: safe tune. a/c works, p/s works, high output alternator, 17x7.5 gram lites
retune coming this summer due to 1.09 chip upgrade, appropriate sized intercooler, and a few other mods.
320awhp@7200rpm approx (during tuning) at 9psi
260awtq@6200rpm approx
Last edited by fhalperformance on Tue Dec 01, 2009 2:43 am, edited 1 time in total.
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby sleeper » Tue Nov 24, 2009 9:24 pm
sorry, but i can not see how you are making 400awhp on that engine..
8.3CR, pump, 14psi will not give you 400awhp.. ( with a 20% drivetrain loss that will give you 500 at the crank..)
So my guess is that this is crank hp or you are running more boost than 14psi.. ( to make 500crank hp at 14psi your engine should make about 260-270hp as na, can`t see that happening on pump fuel..)
sleeper
Postby 3sgt-s » Tue Nov 24, 2009 10:27 pm
fhalperformance
What is all done to your head if you don't mind sharing?
Dees Nuts
3sgt-s
Postby timmey » Tue Nov 24, 2009 10:39 pm
I'm number 1 for FWD? My car is basically stock and runs bad. wtf.
Someone put my car to shame! This is unacceptable.
Timmey
timmey
Postby fhalperformance » Wed Nov 25, 2009 12:22 am
thast why I said as far as I know lol. Car makes 564awhp at 25psi on pump and 320awhp at 9psi so i just figured it out from whp per psi.
EDIT- edited by post to say around 15 psi instead of 12.
264 cams, shimless buckets, oversized valves, street port, cam gears, exhaust fully ceramic coated, ...
Last edited by fhalperformance on Tue Dec 01, 2009 2:44 am, edited 1 time in total.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby CSAlltrac » Mon Nov 30, 2009 3:46 am
Heres mine, I dynoed with my old ECU then my new one to see the gains, thats why there are four HP and TQ lines, the higher ones are the new BLITZ ecu
Peak HP:213@5602
Peak TQ:251@3932
Dyno: AWD hub
Brand: Dynapack
Displacement: Stock
Compression: Stock, maybe a little lower due to HKS 2mm HG
Cams: HKS 272s
Turbo: Stock
PSI:17LBS
Fuel: Stock minus SARD FPR, Walbro 255
Octane: 91
ECU: BLITZ reflash with cuts eliminated and a SAFC2
Motor was rebuilt along with the turbo, TVIS eliminated and was dynoed with about 50k on rebuild
Re: AllTrac.net Dyno Top Ten
Postby TheNubkins » Tue Feb 02, 2010 4:59 pm
Peak HP: 261.9@5900rpm
Peak Torque: 243.6@5075rpm
Type of Dyno: AWD
Brand of Dyno: DynaPak
Engine Displacement: Stock
Engine Compression: Stock
Camshafts: Stock
Turbo: T3/T4 46trim
Turbo Pressure: 19psi
Fuel: 800cc w/ ATS Racing bored fuel rail and 255 Walbro pump
Fuel Type: 94oct
Engine Managment: ViPEC V44
Other Info: Stock intake removed for run(to simulate future straight intake), ST185RC wta intercooler core, AFCO twin pass Mustang Cobra heat exchanger, and 3inch Motoria twin tip exhaust without cats.
The Nubkins
-2001 VW Golf TDI
TheNubkins
Postby Mafix » Wed Feb 03, 2010 12:37 pm
actually i'd believe i'm #1 for FWD. but this is an AWD comparison. so i'm not quite elegible.
Re:
Postby gt4tified » Thu Feb 04, 2010 2:37 pm
CSAlltrac wrote:Heres mine, I dynoed with my old ECU then my new one to see the gains, thats why there are four HP and TQ lines, the higher ones are the new BLITZ ecu
Peak HP:213@5602
Peak TQ:251@3932
Dyno: AWD hub
Brand: Dynapack
Displacement: Stock
Cams: HKS 272s
Turbo: Stock
PSI:17LBS
Octane: 91
I'm glad to see the power held a bit longer at the higher rpms cuz i was concerned that those cams would have been activating at a point where the turbo wasn't able to efficiently keep up.
I have 272's also and I am eager to see where my power will come in with a CT20b and with the TVIS also removed. I will be running on an oem ecu just to break in the engine though and would then put in my aftermarket ems.
gt4tified
Images: 5
Postby ChrisD » Thu Feb 04, 2010 5:18 pm
Mafix wrote:actually i'd believe i'm #1 for FWD. but this is an AWD comparison. so i'm not quite elegible.
I suppose I did a 234whp on a Dyno Dynamics, but I'd like to get some runs in on a Dynojet this year to compare. I think I'd be looking at 265 or so on a DJ.
1988 ST165
1994 ST205 WRC
ChrisD
Postby Mafix » Thu Feb 04, 2010 6:08 pm
yeah once i get my trans fixed i really need to redyno mine. i'd like to see where i am at 28psi on race gas. should be the highest gen 1 i've ever seen.
Postby redGT4 » Thu Feb 11, 2010 12:02 am
Thought i'd add my results. Running super rich at around 10.7 afr's. Stock, no internal mods. 10psi.
103.5 kw @ 148kph at the wheels.
188.2 nm @ 144kph.
Super richness is killing the power.
54 trim hiflowed ct26; Custom top mount;2 1/2" exhaust; Turbosmart boost controller(not fitted); Autometer CF series; Everything else stock; The Haunter of the Hills.
redGT4
Postby 6strngs » Thu Feb 11, 2010 5:46 am
redGT4 wrote:Thought i'd add my results. Running super rich at around 10.7 afr's. Stock, no internal mods. 10psi.
103.5 kw = 138.8 Horsepower
188.2 nm = 138.79 lb-ft
ouch, I would expect a little higher than that
94 Celica GT - Sold
00 Celica GTS - Sold
88 Alltrac ST165 - Sold
04 Subaru WRX - Daily drive/fun car
69 Pontiac LeMans - project car
6strngs
