AllTrac.net Dyno Top Ten
Re: AllTrac.net Dyno Top Ten
Yeah it hits a little later than I would like it to. I feel like it kind of has the SRT4 syndrome. It doesnt really get spooled until 3500rpm. I am a little surprised that it came out that way but maybe thats just how the .50 roles or maybe my exhaust is not big enough. Its only a 2.5inch. I am going to get some bigger injectors in a few months and have it re-tuned at about 18psi and have the redline bumped up to 8 grand so we will see what I am pushing then.
Here is a link to my project thread that has the full build on it. Maybe that will explain some of the map questions.
viewtopic.php?f=44&t=23295&start=90
1992 Alltrac - 350whp - SOLD
EricGT4 - Club Member
It would be nice if on the first couple posts we had the dyno list link to the dyno sheets...!
-Towels
-Towels
2003 S2000
1985 300TD
1985 300TD
WarTowels - Gold GTfour God
will get dyno sheet later but...
after all the changes (ems, ignition, trans, diff)...
341whp. f'ing sweet. i could not get the dyno to read my torque, the ignition signal post ignitor is noisy or something? i need to make a loop cable pre ignitor.
- Mafix
- Gold Member
@Mafix: i just saw that you also run a Haltech. I'm having problems with the ignition at over 1.1bar of boost. The home edge should be falling like the trigger edge but I can't get it to run like it should. Could you share your settings with me? Thanks!
facelift ST205
abraxxa - Club Member
which series haltech? what are you using for a signal?
- Mafix
- Gold Member
A Platinum 1000 with the stock sensors from the distributor.
facelift ST205
what plugs and what is firing them?
- Mafix
- Gold Member
I had NGK heat grade 8 and switched to Denso IK22 this year. The rest of the ignition system is stock.
facelift ST205
you need bkr7's at a 20 thousandths gap
- Mafix
- Gold Member
The IK22 are the same heat grade as NGK 7th.
The gap is 0.8mm like they come out of the box.
facelift ST205
Peak HP: 279.2@5500rpm
Peak Torque: 292.6@4250rpm
Type of Dyno: AWD
Brand of Dyno: Mustang
Engine Displacement: Stock
Engine Compression: 9.0:1
Camshafts: Stock
Turbo: CT26 50 Trim
Turbo Pressure: 20psi
Fuel: 630cc 125psi Shurflo pump
Fuel Type: 92oct
Engine Managment: Autronic SM4
Other Info: 3" DP & Exhaust, 4" Intake, 50/50 Water/Meth
93 Black AllTrac
13 Scion FRS - Current Daily Driver
81 Black/Blue Celica - Sold
2007 Silver Tacoma Sport
93cc - Club Member
abraxxa wrote:The IK22 are the same heat grade as NGK 7th.
ik22's get eaten in these heads for some reason.
- Mafix
- Gold Member
Most of the guys in the gtfour.ch forum have them for years without problems.
But I'll swap them for my old PKR8's and give it a try.
facelift ST205
det kills IK's v easily...
- MrDB
I`v been running ik24`s for a few years now.. and they seem to work great..
- sleeper
