AllTrac.net Dyno Top Ten
Re: AllTrac.net Dyno Top Ten
Postby Hotrodhendrix » Tue Aug 16, 2011 2:28 pm
Hic wrote:I never had a failure with my COP's. Cheap, reliable and easy to get. Internal triggers, no spark cables....and these fit perfectly to 3Sgte valve cover. What more can you want?
The problem with motorcycle COP's is that these need power ignitior, and VW do not. It is in the coil itself.
Very interesting. I will toss this info over to the 3sx guys. 8)
Postby l0ch0w » Wed Aug 17, 2011 1:17 am
I like the mount you came up with, if its cool with you I may use a similar idea for my yukon coils...
Andrew
1991 Red Alltrac
l0ch0w
Postby Hic » Wed Aug 17, 2011 8:21 am
I did some 600hp 3sx mitsubishi's and always used stock ignition. Worked like a charm.
Hic
Postby Hotrodhendrix » Wed Aug 17, 2011 12:35 pm
Mine was in that hp range and used the stock ignition as well. Some wanted more hp or just the fact that the cop is hidden which is the reason I wanted it. :P
Postby ST185pinjo » Sun Dec 11, 2011 12:52 pm
We went to the dyno last month.
My stock dyno is on page 1 of this thread.
Peak HP: 281 AWHP@6719rpm
Peak Torque: 382[NM] or 281 lbf ft
Type of Dyno: AWD
Brand of Dyno: superflow
Engine Displacement: Stock
Engine Compression: Stock
Camshafts: intake = gen3 3sgte, exhaust =stock
Turbo: GT3071, 0.63
Turbo Pressure: 1,2 bar = 17psi
Fuel: walbro 255, 800cc Sard
Fuel Type: 97ron
Engine Managment: Autronic SM4
Other Info: Gen3 WtA, and too small radiator. Blitz Active clutch.
ST185pinjo
Postby mixer72 » Thu Dec 22, 2011 5:05 pm
Peak HP: 395.7bhp
Peak Torque: 370ft/lbs
Type of Dyno: AWD
Brand of Dyno: Dyno Dynamics
Camshafts: 264
Turbo: Turbotechnics S148 Hybrid
Turbo Pressure: 1.55bar
Fuel: Duel feed (800cc injectors, wibro pump, sard regulator,8mm board rail)
Fuel Type: 98 Octane
Engine Managment: HKS
Other Info: 3" turbo-back , FMIC
mixer72
Postby Hotrodhendrix » Fri Dec 14, 2012 12:57 pm
Dyno Sheet
Peak HP: (269@6700rpm)
Peak Torque: (219@5600rpm)
Type of Dyno: (AWD)
Brand of Dyno: (Mustang)
Engine Displacement: (Stock)
Engine Compression: (Stock)
Camshafts: (stock)
Turbo: (TD06 20G)
Turbo Pressure: (9psi)
Fuel: (Bored fuel rail)
Fuel Type: (91oct)
Engine Managment: (Blitz Access ECU)
Other Info: (FMIC 2.5 piping, 3' mandrel exhaust flow through design mufflers, TVIS delete, tial wastegate, AVCR.)
Ran with AVCR off so tial big red spring (9si) net 269.
Same setup on really crappy 2.5 exhaust with fart can net 219 (9psi) before. 50 awhp increase although the turbo did spool quicker before.
~James
~James
Postby Mafix » Sun Dec 16, 2012 1:18 pm
meh why not: it's changing in 2 days anyways so here is the dyno for 2012. also the lower numbers on the graph are 2011.
Peak HP: 368.9
Peak Torque: 337.39
Type of Dyno: 2WD
Brand of Dyno: Dynojet 4th gear pulls
Engine Displacement: .020 overbore
Camshafts: Stock n/a cams
Turbo: precision cea5858
Turbo Pressure: 20psi
Fuel: walbro 255, rc780cc, stock rail, aeromotive reg
Fuel Type: 93 Octane
Engine Managment: haltech p1000
Other Info: fwd swapped auto-x car. lots of things changed.
Postby Mafix » Wed Dec 19, 2012 12:23 am
and now it's 370whp and 355tq with the 46mm restrictor plate preturbo. lol.
Postby tubasteve » Wed Dec 19, 2012 12:25 am
Going nascar on us.
tubasteve
Postby Mafix » Wed Dec 19, 2012 1:27 am
required for my racing sanction. shit lot of good that did them.
Postby SkagTits165 » Wed Jan 02, 2013 7:43 pm
We will not be including FWD swapped cars, MR2's or other platforms with 3s based motors. All Tracs/GT-Fours ONLY!
you know who you are
SkagTits165
Postby deadxwreckoning » Wed Jan 02, 2013 8:27 pm
Peak HP: 504@6400rpm
Peak Torque: 420@6350rpm
Type of Dyno: AWD
Brand of Dyno: DynoJet
Engine Compression: 9.0:1
Camshafts: GSC S2 274
Turbo: Precision 6262 (S cover) dual ball bearing/billet wheel
Turbo Pressure: 23psi
Fuel: 2000cc/2 walbro 255lph pumps
Fuel Type: E85
Engine Management: (AEM EMS)
Other Info: 2nd gen 3s block mated to 3rd gen 3s head, 9k redline, stock exhaust manifold :)
1995 JDM Toyota Celica GT-FOUR
Precision 6262 DBB @ 23 lbs
Fully Built - AEM Standalone - E85
504 AWHP 3S-GTE FTW!
deadxwreckoning
1995 Toyota Celica
Postby SkagTits165 » Wed Jan 02, 2013 10:05 pm
THATS WTF IM TALKIN ABOUT.NICE
SkagTits165
Postby deadxwreckoning » Wed Jan 02, 2013 11:35 pm
vukatron wrote:THATS WTF IM TALKIN ABOUT.NICE
Haha thanks man. I'll be back soon with a Full Race turbo mani and 700awhp :)
deadxwreckoning
1995 Toyota Celica
Users browsing this forum: Baidu [Spider], Bing [Bot] and 2 guests
