You could end up spending that much on a computer & tuning, not to mention all the other crap you would want/need to make the whole thing run right. If I were you I'd stick with the stock turbo for now, do your basic mods: straight intake, cone filter, mbc, fcd, fan on ic or go fmic, catch can, boost guage, blow off valve/bypass valve, egt guage & probe. Then comes one of the bigger costs: exhaust. Those right there will run you close or over 2 g's depending on what you choose for exhaust and if you decide to get a fmic. After that is when all the big ticket items come into play. Injectors, fuel rail, fuel pump, fpr, engine management, upgraded turbo etc etc..... there are so many items your going to need to run higher hp reliably and safely. If this is your first project, start slow, you gotta learn to walk before you run. Be smart about what your doing, weigh all your options and ask questions. I've always believed that the only dumb question is one that was not asked. And just remember if you want to make your car fast you have to find a way to make it stop just as fast, a lot of people overlook braking when they upgrade thier cars. There are just sooooo many different things to weigh when building up a car.
