berk tech downpipe arrived !!!
Postby st185rc » Sun May 24, 2009 12:17 am
I've never done a downpipe install before so here's my question: is it ok to mate this thing up to the stock b-pipe? from 3" to stock diameter of the midpipe seems to not bode well. when i think about it, it the exhaust that leaves might be heat up the mid pipe too much at the joint where it goes back down to a 2.5"ish restriction.
st185rc
Re: berk tech downpipe arrived !!!
Postby JamesDeane » Sun May 24, 2009 5:15 am
st185rc wrote:I've never done a downpipe install before so here's my question: is it ok to mate this thing up to the stock b-pipe? from 3" to stock diameter of the midpipe seems to not bode well. when i think about it, it the exhaust that leaves might be heat up the mid pipe too much at the joint where it goes back down to a 2.5"ish restriction.
i installed a berk tech dp on my car and left the stock exhaust for 3 months before i got a 3" exhaust system. I never had any issues.
JamesDeane
Postby RedCelicaTRD » Sun May 24, 2009 6:04 am
It's fine. It's not optimal for power but it is just fine. As for heating the mid-pipe, it will be ok. No need to worry.
Postby st185rc » Sun May 24, 2009 4:01 pm
cool thanks guys, time to get out the socket and start putting this bad boy on
st185rc
Postby CelicaAllTrac92 » Sun May 24, 2009 4:58 pm
Have fun getting those bottom 2 studs out. I recommend vice grips and a lot of patience!
92 All-Trac
Photo Album
CelicaAllTrac92
Postby st185rc » Sun May 24, 2009 5:05 pm
oh man, that looks like utter hell.....
st185rc
Postby CelicaAllTrac92 » Sun May 24, 2009 5:10 pm
It'll all be worth it in the end!
92 All-Trac
Photo Album
CelicaAllTrac92
Postby CSAlltrac » Sun May 24, 2009 5:37 pm
They make a socket for that job.............makes it a breeze.
Postby CelicaAllTrac92 » Sun May 24, 2009 5:45 pm
How do you fit it in there? That was my problem.
92 All-Trac
Photo Album
CelicaAllTrac92
Postby CSAlltrac » Sun May 24, 2009 6:49 pm
I had a shorty so it wasnt a problem :shrug:
Postby st185rc » Mon May 25, 2009 9:32 am
one more question: will the hpc coating be enough to keep the heat down or should i get heat wrap to get things a bit more insulated?
st185rc
Postby ___Scott___ » Mon May 25, 2009 12:48 pm
Putting any sort of wrap over an HPC coating will void the warrantee of the coating.
That said, when it comes to insulation, more is better.
Personally I wouldn't use the wrap. It looks so nasty after just a short time.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby CSAlltrac » Mon May 25, 2009 4:15 pm
^+1 I wrapped mine, really wish i didnt, it left stains on the coating and now it looks all poopy.
Postby toayoztan » Mon May 25, 2009 7:05 pm
Some of the heat wraps are fiberglass....god that stuff can get everywhere and is horrible.
If the HP coating becomes bad, get it coated with titanium coating or something that is better and more heat resistant.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby gt4rcdude » Tue May 26, 2009 3:57 pm
CelicaAllTrac92 wrote:Image
All you had to do was remove the 4 bolts of the a/c compressor and bungee it out of the way. Downpipe comes right off. I used the copper infused thermal wrap and then painted it with black BBQ paint. Looks great and drops under hood temps significantly. I wrapped it all the way under to the flex pipe.
gt4rcdude
