berk tech downpipe arrived !!!
Postby rrain3288 » Tue May 26, 2009 10:58 pm
iv tryed many ways to pull that off the car. the best way for me was to just pull the banjo bolt from the oil cooler and push it to the side 1/4 inch it will slide right out. just make sure that you pull the radiator first or you will destroy it
Why me!!!!
92 Celica Alltrac-gen 3 swap
rrain3288
Postby st185rc » Wed May 27, 2009 6:17 am
ok so i have problems even before i start taking stuff off my car. i have a problem with one of the bolts not being able to go through the hole because of the angle the bolt has to go in
the bolt that's closest to the right that connects to the b-pipe is the bolt i'm having trouble with. i'm starting to scratch up the hpc coating a bit and i'm having no luck getting it to go in like the one pictured above.
st185rc
Postby st185rc » Wed May 27, 2009 6:23 am
never mind, i got it, i just had to put a piece of paper between the pipe and the bolt and wiggle it in. now my fingers hurt :(
st185rc
Postby gt4rcdude » Wed May 27, 2009 5:40 pm
pretty!
gt4rcdude
Postby CelicaAllTrac92 » Wed May 27, 2009 5:45 pm
gt4rcdude wrote:All you had to do was remove the 4 bolts of the a/c compressor and bungee it out of the way. Downpipe comes right off. I used the copper infused thermal wrap and then painted it with black BBQ paint. Looks great and drops under hood temps significantly. I wrapped it all the way under to the flex pipe.
Oh well, I'll know next time. That was 6 years ago so it's all good.
92 All-Trac
Photo Album
CelicaAllTrac92
Postby RafaCalde » Fri Jul 24, 2009 7:57 am
i don;t know how many of you have a berk tech, but quick question, where did you order it from and how long did you have to wait to get? i want to order one today but i don't want to wait forever to get it.
Rafa
RafaCalde
Postby ChrisD » Fri Jul 24, 2009 1:09 pm
for people going with heat wrap - two tips
1. to keep the mess down, dunk the roll in water first. this also helps you get a good tight wrap
2. you can get silicon spray for coating the heat wrap. use it! it will make it last much longer.
1988 ST165
1994 ST205 WRC
ChrisD
Postby st185rc » Sun Jul 26, 2009 3:29 am
RafaCalde wrote:i don;t know how many of you have a berk tech, but quick question, where did you order it from and how long did you have to wait to get? i want to order one today but i don't want to wait forever to get it.
i ordered mine directly from www.berktechnology.com and the wait isn't too bad, it was about 3-4 weeks.
st185rc
Postby RafaCalde » Sun Jul 26, 2009 5:11 am
well i ordered mine directly on friday. they told me i should have by this coming friday.
Rafa
RafaCalde
Re: berk tech downpipe arrived !!!
Postby awolo » Tue Jul 10, 2012 3:16 am
guys! I didn't want to start a new thread.
I cannot get my stock down pipe off.
Any advice/tips?
Seems like the oil filter thing is in the way. Not sure how to remove it or move it without spilling loosing oil.
Stumped!
awolo
Postby Rpz123isme » Tue Jul 10, 2012 3:26 am
why not kill two birds and change your oil while you are under the hood. Clean oil never hurts a motor!
then you dont have to worry about spilling oil
Hesperia, CA
Rpz123isme
Postby celigts » Tue Jul 10, 2012 3:47 am
awolo wrote:guys! I didn't want to start a new thread.
Any advice/tips?
Stumped!
Hey man. Just did mine the other day and what I did was loosen all the manifold bolts to pull the waste gate far enough to slide the dp off the studs. After that it's the same but the other way around. Hope this helps :)
3SGTE project motor very slow
celigts
Postby awolo » Tue Jul 10, 2012 10:08 am
Any advice/tips?
Stumped!
I was thinking this as well. Glad im not the only one. I will try this today!
But just so we are clear...
Basically, your saying just loosen the exhaust manifold bolts, slide the entire manifold/turbo setup forward, then wiggle the DP free?
awolo
Postby quieter » Tue Jul 10, 2012 10:29 am
just bend the oil line thats in the way and take off the oil filter. use a crowbar or a non filled bar of metal to move it, dont kink it by putting too much pressure! good luck
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby awolo » Tue Jul 10, 2012 6:38 pm
Rpz123isme wrote:why not kill two birds and change your oil while you are under the hood. Clean oil never hurts a motor! then you dont have to worry about spilling oil
Oil is only 500 miles old. Not looking to change it.
awolo
