berk tech downpipe arrived !!!
Postby celigts » Tue Jul 10, 2012 8:05 pm
Yep that's exactly what I'm saying. Thr nuts had to be pretty much all the way loose.
Note. This apparently took me 4hrs to swap. You'll need a swivel or knuckle socket to get to the stupid bolt directly beside the oil dip stick. It was such shit getting it on and off lol. Otherwise it was pretty easy after figuring out the manifold had to be moved. Clean the top of the manifold tho of rocks and crud cuz I had some fall between the gasket layers and now I've got a leak causing me to get mixed reading and making me run very rich
3SGTE project motor very slow
celigts
Re: berk tech downpipe arrived !!!
Postby awolo » Wed Jul 11, 2012 1:05 am
Worked on it for another hour today. Got the cat off, DP is still stuck. :bangshead:
How are you guys removing the studs with the DP still in position??? :shrug:
Looks like ill be doing the manifold loosen technique. Ill have to go buy a swivel socket to get that one bolt off behind the alternator like previously said.
awolo
Postby celigts » Wed Jul 11, 2012 1:56 am
Well atleast you got somewhere. Even if you would take the studs out it wouldn't help cuz by the time you got them
Out you wouldn't be able to get the bottom 2 out. If you can your a magician haha
celigts
Postby Rpz123isme » Wed Jul 11, 2012 4:32 am
awolo wrote:Worked on it for another hour today. Got the cat off, DP is still stuck. :bangshead:
Or u can save some cash and spend 15 mins to pull the alt and bracket.
Hesperia, CA
Rpz123isme
Postby toayoztan » Wed Jul 11, 2012 4:42 am
Ditto.
Tensioner and belt removal.
Top and Bottom alternator bolt.
Unplug, remove alternator.
Remove 3 bolts and remove bracket.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby awolo » Wed Jul 11, 2012 11:35 am
toayoztan wrote:Tensioner and belt removal.
Bryan
Doing this today. Will post back up if another issue arises.
awolo
Postby celigts » Thu Jul 12, 2012 2:37 am
Yea what he said also. I assumed you went as far as also removing the alt. my bad lol. Need to do that to get the one bolt fit the manifold
celigts
