205 IC on 165 motor
205 IC on 165 motor
Postby Rick89GTS » Sun Aug 15, 2004 9:44 am
Wasn't there somebody on this board who did this upgrade? Will the 205 even fit under the hood of a 165?
Rick89GTS
Postby saved_1992 » Sun Aug 15, 2004 6:24 pm
i tried to put on the 205 intercooler on my 165 that has the 1 gen motor. would not fit, the intercooler is too big (wide). i have seen the 205 intercooler on a 2 gen motor in the 165 though, and it fit fine.
i think the problem is the turbo sits higher with the 1 gen than the 2 gen motor. also the intake is closer to the turbo compared to the 185.
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby Rick89GTS » Sun Aug 15, 2004 6:34 pm
I was curious as I may have a line on a 205 IC but don't know how much modding I'd be in for.
Yeah, I think "5Speed" had the 205 IC on a 185 motor in a 165 body.
Heh heh, 3 generations of AllTrac in one car :wink:
Rick89GTS
Postby Zeus » Mon Aug 16, 2004 5:12 pm
yeah rick thats right it was a 185 motor... and my old core :P
Blake Brown
Zeus
Postby Rick89GTS » Mon Aug 16, 2004 6:20 pm
Yeah, to my knowledge, 205 IC to 165 motor hasn't been done yet...
Rick89GTS
Postby saved_1992 » Mon Aug 16, 2004 10:43 pm
well did some measuring the 2 gen exhaust manifold is 4.75" from the flange to the area(edge) that the turbo bolts up to. the 205 is 5.5" and both seem to have the turbo clocked pointing more up. left the 165 at work so i will take more measurements on that manifold later.
will the 205 exhaust manifold bolt up to the 1 gen or 2 gen?
mike
omaha,ne
saved_1992
Postby RedCelicaTRD » Mon Aug 16, 2004 10:45 pm
Nope.
Postby saved_1992 » Mon Aug 16, 2004 11:03 pm
what are the fitment problems? i have the 205 assem and just eyeballing looks close. i would rather not have to take all apart just to check.
was there a pic of them side by side?
mike
omaha,ne
saved_1992
Postby saved_1992 » Thu Aug 19, 2004 11:54 pm
yep redcelicatrd you are right my eyball was off by just soo little the 205 exhaust manifold will not fit.
i am working on getting the 205 intercooler to fit a 1 gen in the 165. will post the results. hopefully this week 8)
mike
omaha,ne
saved_1992
Postby Toyota Guy » Fri Aug 20, 2004 11:01 pm
Mike, how many all-tracs do you have? I heard that you might be selling one soon.
Toyota Guy
Postby saved_1992 » Sat Aug 21, 2004 12:05 am
toyota guy sent pm
mike
omaha,ne
saved_1992
Postby Gary » Sat Aug 21, 2004 4:23 am
Toyota Guy, your sig looks familiar. :)
93 ST185
Gary
Postby Rick89GTS » Sat Aug 21, 2004 11:31 pm
saved_1992 wrote:.....i am working on getting the 205 intercooler to fit a 1 gen in the 165. will post the results. hopefully this week 8)
Looking forward to the results, good luck :D
Rick89GTS
Postby saved_1992 » Sun Aug 22, 2004 12:30 am
well i do know the 205 will fit on a stock 165 if you clock the turbo, but you would have to cut the inlet of the intercooler about 3-4 inches.
i did not want to do that, so out came the 1 gen turbo assem in went the 2 gen exhaust manifold and turbo. i used the adapters for the water and oil lines from the 1 gen and swapped to the 2 gen. now in the process of the adjustments needed to fit.
note with the 2gen exhaust manifold and turbo the intercooler fits with cutting inlet a little. the 2 gen puts the turbo farther away from the engine and sits lower.
mike
omaha,ne
saved_1992
Postby ATSAaron » Tue Aug 24, 2004 1:22 pm
saved_1992 wrote:note with the 2gen exhaust manifold and turbo the intercooler fits without cutting. the 2 gen puts the turbo farther away from the engine and sits lower.
Did your wastegate arm clear the ST165 oil cooler?
Aaron
Aaron Bunch
Denton, Texas
91T MR2 606 rwhp
93T MR2 291 rwhp
Dynojet 248C 1200hp dyno
ATSRACING.NET
ATSAaron
