Stock Boost?
Stock Boost?
Postby -==L=a=N=c=E==- » Sun Aug 15, 2004 9:58 am
What is the stock boost for the ST185. My boost gauge, with my boost controller off has it at 7psi.
Is that right or am i dreaming?
-==L=a=N=c=E==-
Postby Gary » Sun Aug 15, 2004 2:42 pm
7-9 psi.
I hit 10 psi sometimes on a cold day.
93 ST185
Gary
Postby toayoztan » Sun Aug 15, 2004 10:30 pm
I always thought it was 6-8psi. Depending on the weather, I hit anywhere around there. Mods such as DP, etc can increase your boost to an extent too w/o any boost controller.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby -==L=a=N=c=E==- » Mon Aug 16, 2004 2:40 am
Thanks guys. Reason i ask, is that i've had problems with a boost leak. And i think i've finally tracked it down. And i never had a boost gauge on the car before the boost leak happened. So hence why i ask.
Mods wise, i have a 3inch exhaust, with no stock CAT and the stock downpipe. So im guessing 7PSI is good. I get around 6-8PSI all the time now.
All good, thanks for the replies guys.
-==L=a=N=c=E==-
Postby SuperWhite92 » Tue Aug 17, 2004 12:15 am
I hear 9 for most people, but for some reason, mine always ran 14psi when it was stock. No boost controller, Bone Stock. And I still haven't found fuel cut, which has not been disabled as far as i can tell.
Ignoring the fact my car is freakish.... I'd say about 9psi is right.
Shaun
SuperWhite92
Postby Gary » Tue Aug 17, 2004 12:48 am
OK guys, according to the BGB,
7.1-11.8 psi while driving with the engine running at 2800 rpm or more with the WOT in the 2nd gear.
93 ST185
Gary
Postby toayoztan » Tue Aug 17, 2004 12:55 am
SuperWhite92 wrote:I hear 9 for most people, but for some reason, mine always ran 14psi when it was stock. No boost controller, Bone Stock. And I still haven't found fuel cut, which has not been disabled as far as i can tell.
I had the exact same problem you did. I hit around 12-13psi all the time w/o any fuel cut when i bought my 93 alltrac. I couldn't find the problem, so i decided to change out my WG actuator from my 92 alltrac. However, while removing the 93 actuator, i found a rip in actuator hose leading to the VSV. You might want to inspect the hoses around there. It might have to do with the fact that since air does leak through that hose, it takes just a bit more psi for the VSV to "see" stock psi. That's just my theory.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Gary » Tue Aug 17, 2004 12:58 am
Sound right Bryan. The leak will act like a bleeder valve and the actuator will keep the wastegate shut due to there is not enough pressure.
93 ST185
Gary
Postby -==L=a=N=c=E==- » Tue Aug 17, 2004 3:50 am
Okay, just quicly help me.
Reason i asked what ths stock boost levels are, is that i 'think' i have a leak somewhere.
My vaccum is at 20hg/in but when i go onto boost, my gauge is at anywhere from 5-9psi at the moment. So the leak would be somewhere between by turbo and inlet yes? a loose coupling perhaps?
Would this also explain then when i turn up the boost, the spiking and settling affect? or is this more MBC related?
-==L=a=N=c=E==-
Postby Gary » Tue Aug 17, 2004 3:57 am
Your vacuum reading sounds healthy to me.
I think it's more of the MBC setting. Do you have one?
Have you disconnected and capped hose from the wastgate actuator to t-vsv?
93 ST185
Gary
Postby -==L=a=N=c=E==- » Tue Aug 17, 2004 8:54 am
Gary wrote:Your vacuum reading sounds healthy to me.
Tvis is pulled and plugged. I think its the MBC that i have installed.
Ill retighten my clamps again. I have an unmodified intercooler that im gonna install tommorrow and see how that goes.
Cheers
-==L=a=N=c=E==-
Postby Gary » Tue Aug 17, 2004 2:46 pm
Richard,
Someone on Celica.net have problem with his MBC. It turns out he didn't drill a small hole to bleed air out.
BTW, I guess you meant t-vsv, not the t-vis
93 ST185
Gary
Postby -==L=a=N=c=E==- » Tue Aug 17, 2004 8:26 pm
Gary wrote:Richard,
T-vsv, tahts right. Im pulling the MBC today. Just going to go back to the stock controller.
-==L=a=N=c=E==-
Postby Griffin » Tue Aug 17, 2004 10:17 pm
The stock controller is very restrictive. Mine can only make about 10 PSI with my cams and echaus and all, but I made over 24 PSI with the wastegate actuator shimmed out to keep it shut. I'm looking into a better quality VSV to control pressure bleedoff.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby -==L=a=N=c=E==- » Wed Aug 18, 2004 12:21 pm
okay, this boost leak is realy frustrating. Soemtimes it'll boost 9psi, soemthing 6psi, sometimes 7psi, sometimes 8psi.... Sometimes it'll boost up, and then slowly drop down. Sometimes it'll hold it. Playing with the bleed valve sees it boosting higher, but then dropping. or it will hold boost. Its all over the place.
Ive tracked down every vaccum leak. Ive sealed upa ll the hoses on the intercooler run. The only thing left is a tired wastegate. Or something else. Maybe one of the vaccum lines is leaking under boost or something.
-==L=a=N=c=E==-
